Old 10-18-2013, 11:35 AM   #1
Guest
Draining Water Heater-Question
I understand how to drain my water heater (winterizing next weekend), but my question is:
I know the plug is VERY tight, I'm getting a socket to use (1 1/16", correct?) How hard can I crank in that thing? I Don't wish to damage my tank, but it needs to be drained of course.
John4th is offline   Reply With Quote
Old 10-18-2013, 11:41 AM   #2
Fulltime family RVer
I can't answer the "how hard" question as mine was pretty easy the first time and then I wrapped tape around the threads when I re-installed it.
But- you're right about the 1 1/16" socket. I'll also recommend at least a 3" socket extension. I had to be really careful about not scratching my camper the first time that I took mine out.
Old 10-18-2013, 11:43 AM   #3
jtstromsburg's Avatar
I ended up using a 18v, 3/8 "
Dewalt impact. Worked fine. I made sure to use tape when i reinstalled
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
Old 10-18-2013, 03:53 PM   #4
RPAspey's Avatar
look at it this way, you HAVE to get the drain out or risk the water freezing and rupturing the tank. So, if you damage the tank in the process of removing the plug, it was gonna need replaced in the spring anyway.
Mine was very hard the first time. As stated previously use Teflon tape.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 10-18-2013, 04:47 PM   #5
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
I just replaced my hot water heater anode on a 7 month old 5er. Just like ependydad stated, I used a 3" extension and had to really reef on the wrench in order to turn it. I have to say that you're probably going to have to really put some muscle into it and don't forget to tape the threads when you reinsert it.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 10-18-2013, 05:16 PM   #6
crunchman12001's Avatar
I believe the factory uses pipe dope on the threads. The stuff holds hard but when you break the bond free, it will spin out with ease.
crunchman
2015 F-250 FX4
Old 10-19-2013, 11:23 AM   #7
Mine was a real bearcat to remove. Had to soak it with Liquid Wrench to finally get it loose.
Acsimon
2008 Jeep Grand Cherokee (5.8 Hemi)
2013 Flagstaff Micro Lite 21FB
acsimon is offline   Reply With Quote
Old 10-19-2013, 11:44 AM   #8
Ford Idaho's Avatar
crunchman
That is the way mine was done and it is just a 3/4 plastic plug because I have no anode.
I have some pipe dope that I will use in the spring, till then I just put the plug in a couple of turns by hand.
Old 10-19-2013, 12:34 PM   #9
Herk7769's Avatar
crunchman
This was my experience as well. I found you do not have to tighten the anode all that much when you install it. Just snug enough that it will not leak under pressure. Next year it will come out easy as pie...
HAM CALLSIGN - KC3FFW
Old 10-19-2013, 02:03 PM   #10
Gregg Willow's Avatar
Through my PDI the tech had removed the anode and let the water drain. Then wrapped the threads with tape and reinstalled. Came out easy the other day when I winterized.
Oh, by the way Herk. Putting the corner of a shop paper towel into the drain hole and letting it siphon all of the water out of the heater works awesome. Great tip!
To others, just kind of twist the corner of a "heavy" paper towel into the drain hole, get it far enough to sag to the bottom, then hang the rest over your hanging heater door and walk away for awhile. Do not remove until the towel stops dripping.
2016 Ford F-150 4x4 Supercab XLT EcoBoost
2012 Salem Cruise Lite 221RBXL, Andersen No Sway WDH, (2) Honda EU2000i's
Gregg Willow is offline   Reply With Quote
drain, heater, water, water heater
