Old 08-23-2015, 05:32 PM   #1
Drawing Fresh Water From Winterize Port?
I was wondering if it's okay to pull water from a portable jug using the winterize port on the side of the camper? We're looking to boondock in a few weeks and want to bring a few potable water jugs for extra water. I've tried it out in the yard and it seems to draw from the jug just fine. I just wanted to make sure it wouldn't hurt anything. Thanks.
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
GearHd6 is offline   Reply With Quote
Old 08-23-2015, 05:43 PM   #2
Ford Idaho's Avatar
It will be fine, jug size will be the limiter.
Old 08-23-2015, 05:45 PM   #3
Jimandchris's Avatar
It will work but I don't believe it will fill the fresh water tank, only the plumbing. Some folks however have pulled the water from the jug with the winterize valve, then use the outside shower to fill the fw tank if its close to the fw fill port.
2014 Roo 23SS
2013 GM Sierra CC
Prodigy P3 Brake Controller
Equal-i-zer Hitch
Nites Camped 2016 -25
Jimandchris is offline   Reply With Quote
Old 08-23-2015, 05:48 PM   #4
I was thinking I'd just pull from the jugs as needed rather than try and fill the fresh water tank. I have 3 of the 7 gallon blue jugs that I'll draw from first and when they're gone switch over to my fresh water tank.
2013 Rockwood 2109S
Old 08-23-2015, 05:56 PM   #5
I do it a lot when boondocking to fill my trailer potable tank. No problems!!
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 08-23-2015, 06:02 PM   #6
Who Dares, Wins
doc73's Avatar
Do the same thing when we are dry camping. Use the outside shower to fill the tank to save me from needing to go out and switch containers often.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 08-24-2015, 12:42 PM   #7
TGR
TGR's Avatar
The winterizing port will likely benefit from a sanitizing process and a good flush, especially if it was used to draw antifreeze into the RV for winter storage.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
Old 08-24-2015, 08:38 PM   #8
dieselbobcat's Avatar
I do the same thing, but have pulled from a 48 gallon water bladder in the back of the pickup... Fill the bladder after setting up camper, if I can't gravity fill tank then hookup to winterizing port and pull from bladder. Rather unhook and shut off pump when we leave with TV than pump and fool with transferring water.
2014 Rockwood Ultralight 8312SS Diamond Edition
2016 F350 Lariat Ultimate Super Duty Crew Cab 4X4
Northern NJ - God Bless America!
dieselbobcat is offline   Reply With Quote
Old 08-25-2015, 09:07 AM   #9
I've used the winterize port to fill the water tank in my Georgetown that doesn't have an outside shower. I use a hose adapter on the bathroom sink and run my fresh water hose from it to the fill port. The pump sucks water from the 5 gal jug, the sink fills the hose which feeds the tank.
This leads to another thought - a cross connect (with valve) between the pump output and the fill line for the fresh water tank inside the plumbing compartment. This would allow refilling the fresh tank from jugs without running a hose through the rv.
Phil
pmsherman is offline   Reply With Quote
Old 08-25-2015, 09:24 AM   #10
I think the OP has it figured out. Use the portable jugs first and then switch over to the onboard tank.
fresh water, water, winter, winterize
