Old 01-22-2012, 06:44 PM   #1
Mountainmanbob's Avatar
drip drip coming from the rear end - Mini Light - M-2106
yes
the old drip drip
started last week
while out in the desert
coming from up above
grey water tank far rear end
looks like it is time
to take some THINGS apart back there
so as to locate leak
I'am sure it would cost hundreds
at the local RV repair place
fixed enough pipes in my life
should be no problem
IF
I can find that leaking THING ??
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 01-22-2012, 07:10 PM   #2
sherdep's Avatar
I take it - its not under warranty
Hopefully you will find it - I know on my 2306 everything looks pretty easy to find so hopefully you will find it fast.
I would look inside the bathroom or under the tub to see if it is above the tanks and work your way down just to verify it isnt inside
Good Luck
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 01-23-2012, 06:25 AM   #3
need to find my inspection mirror
thanks sherdep
no warranty - bought used
good idea checking bathroom first
those THINGS come in handy at times
and
I may need a 4x8 piece of plywood
our driveway is medium size gravel
painful laying on that stuff
Old 01-30-2012, 11:31 PM   #4
ready now for our next trip
got around to those two leaks today
the one in the rear of trailer
was located just inside behind
the outside shower
those are some cheap plastic hoses
flex was gone - hardened and cracked
replaced 2 with standard 1/2 braided type
put a new faucet in the kitchen sink also
it also started leaking last time out
I was grateful to be able to
get to the leak fairly easily
some of these access places
on this trailer are pretty tight !
ready now
for our next trip
Mountainman
Old 02-01-2012, 05:32 PM   #5
sherdep's Avatar
glad to see you got it taken care of
Old 02-02-2012, 12:17 AM   #6
thank you sherdep
and I saved some money
total cost 40 dollars
prox cost at the RV repair place 200 bucks
and probably would not have gotten the better hoses
Mountainman
Old 02-02-2012, 08:08 AM   #7
jim44646's Avatar
drip drip coming from the rear end . Sounds like a personal problem to me.
jim44646 is offline   Reply With Quote
Old 02-02-2012, 09:42 AM   #8
no problem
wrong site
you must have gotten mixed up
and thought you were on your personal medical web site
no problem
have a good day
Mountainman
