Old 09-21-2013, 11:16 AM   #1
dripping flex lines
so is there a way to prevent the flexable lines from leaking in cold weather? the PEX connections are fine. the issue is with the semi-clear flexable lines. When they get cold they tend to drip around the connections. i have tried recrimping them and even replacing the bands on one or 2 of the connections same result. leaving the bath vanity doors open (where the connections are) to help keep them warmer works but is a pain.
anyideas? anyone have a similar problem?
sayety is offline   Reply With Quote
Old 09-21-2013, 11:47 AM   #2
So you think it's condensation then? I would think if the moisture is that high in your RV you're going to have more severe problems soon. I suggest opening a vent and do whatever else you need to do to get the moisture out.
Old 09-21-2013, 12:08 PM   #3
Ford Idaho's Avatar
Not sure which trailer you have.
Are these clear lines hooked to the bathroom faucet?
