Old 10-04-2013, 08:23 AM   #11
Rather than replacing the faucet due to the fact that it is new, I'd take the leaking faucet apart and just clean and lube it. Simple, takes about 5 minutes and some Danco silicone grease.
Old 10-04-2013, 09:07 AM   #12
Arefbee's Avatar
X2
Then get a good filter. Chances are it is construction debris in the valve (based on age of unit), but it could be campground water junk too.
2011 PrimeTime Tracer 2600rls
2001 GMC Yukon XL 2500, 6.0L 4.10:1 axle ratio
Nights camping 2014 - 17
2013 - 15
Arefbee is offline   Reply With Quote
Old 10-04-2013, 09:51 AM   #13
Herk7769's Avatar
My toilet valve clogged when I drained my hot water tank with the low point drains. A nodule of calcium got sucked into the pipes and when I flushed and de-winterized the camper the incoming water pushed the nodule into the flush valve.
Name:	Camper Bidet 022.jpg
ID:	40637   Click image for larger version
Name:	Camper Bidet 025.jpg
HAM CALLSIGN - KC3FFW
Old 10-06-2013, 03:48 PM   #14
mamentt's Avatar
Got It Fixed!
There was some junk in the cold water faucet. The junk seemed to be from new construction, new trailer. Not sure how the junk got in there, but it happens. I just started removing stuff from the handle down and saw the problem.
Thanks for all your input.
mamentt is offline   Reply With Quote
faucet
