10-03-2013, 03:55 PM
Dripping kitchen faucet
I have a 2014 Flagstaff 29RLSS trailer. I have a faucet in the kitchen that continually drips from the cold water side. (hot side is okay)
Can this faucet be repaired with home plumbing parts, or does the whole unit need to be replaced? Are replacement parts only available from an RV center?
Thanks for info.
10-03-2013, 06:45 PM
I'd call a RV plumber..........................
1999 Dodge Ram 1500 5.9L 90,000 miles
2014 Grey Wolf 26DBH
10-03-2013, 06:57 PM
I'd fix it myself. Not sure what you have but their all pretty simple.
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
10-03-2013, 07:58 PM
Professional Curmudgeon
If the faucet appears to be cheaply built, I'd consider replacing the entire thing with a high quality residential unit. Otherwise, simply relieve the water pressure, remove the knob, and unscrew the bonnet. It probably does not use washers, but it may have a foreign object blocking the valve from closing completely.
2022 Cougar Half Ton 24RDS fifth wheel
2014 Coachmen Catalina 253RKS (sold)
2017 F350 6.7L DRW CC LB 4x4 Lariat
10-03-2013, 08:21 PM
Thanks for info.
2014-take it to the Dealer. The Fixtures are plastic,buy a Home type and let the Dealer put it in for free Labor,you both will be Happy! Youroo!!
10-03-2013, 08:22 PM
Shut the city water and the water pump off, open the hot and cold faucets, then remove the cold water handle and remove the center of the faucet. There is probably a pc of ? somewhere on the plastic or O ring. Go to Lowes/HD and get some Danco silicone grease and lube the inside and re-assemble. While you're at it, do the same for the hot side to prevent it squeaking later on. Re-assemble and turn the city water/water pump on and see what transpires.
10-03-2013, 08:55 PM
As new as it is, nothing is wore out. Take it apart and get what ever junk is in there that is causing the leak.
Brother Les
10-04-2013, 07:57 AM
I think you all are more than likely correct, there may be some foreign matter in the faucet. I know it is under warranty, but that is a long haul from our house.
Thanks for all your help.
10-04-2013, 08:08 AM
I think you all are more than likely correct, there may be some foreign matter in the faucet. I know it is under warranty, but that is a long haul from our house. Thanks for all your help.
My sister and brother both replaced theirs with residential models from Lowes. Look good and work great!
10-04-2013, 08:18 AM
Since there are no individual shut off valves at each sink, back flushing the valves is hard to do. With valves you just shut off the hot or cold to find out which valve is leaking, then remove that feed line and crack open the "good" valve to flush the offending matter into a bucket.
This is an edit: I just realized this will not work. Disassembly or replacement are your only options.
Removing these valves can be problematic (again plastic) and if the repair does not work you might consider replacement.
Single Lever Kitchen Faucet with Pull-Out Spray - Brushed Nickel - Phoenix Products SW2103-06-01NLI - Faucets & Inlets - Camping World
This is the one in our Flagstaff.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
10-04-2013, 08:23 AM
Rather than replacing the faucet due to the fact that it is new, I'd take the leaking faucet apart and just clean and lube it. Simple, takes about 5 minutes and some Danco silicone grease.
10-04-2013, 09:07 AM
X2
Then get a good filter. Chances are it is construction debris in the valve (based on age of unit), but it could be campground water junk too.
2011 PrimeTime Tracer 2600rls
10-04-2013, 09:51 AM
My toilet valve clogged when I drained my hot water tank with the low point drains. A nodule of calcium got sucked into the pipes and when I flushed and de-winterized the camper the incoming water pushed the nodule into the flush valve.
10-06-2013, 03:48 PM
Got It Fixed!
There was some junk in the cold water faucet. The junk seemed to be from new construction, new trailer. Not sure how the junk got in there, but it happens. I just started removing stuff from the handle down and saw the problem.
Thanks for all your input.
