Old 09-04-2013, 08:29 AM   #11
rycej's Avatar
I was going to sort of ask something along this line myself. Not if it was safe, just if it was better to fill it right up or only half way (was thinking about the sloshing issue (as avolnek mentions). I'm going on an overnight dry run and it may just be myself, but I will need the shower for the next day, and the bathroom. So I was thinking fill it full, or only part way. The sloshing was what I was worried about.
From some of the answers to the OP question, I think full is fine.
2013 F150 v8 4x4 Supercab
2014 Surveyor 192T
rycej is offline   Reply With Quote
Old 09-04-2013, 08:38 AM   #12
another_newfie's Avatar
In our TT we did almost all the time. Largely because of work schedules we would often arrive at the CG very late and I did not want to have to deal with filling the FW that night (where we camp there is no on site water). Our TT was stored in a storage yard. On the way out of any trip I'd always fill the tank, then it went back to the yard full and ready for the next trip.
On one of our trips traveling very late we hit an un-signed dip in the highway, and bounced REAL hard. The end result was the straps on the FW tank broke and since it was right on top of my rear axle it took out the axle as well. Bent it real good. Luckily my dealer and FR did stand up and repair all the damage, but initially FR did state that they would not cover the damage. When my dealer challenged them saying that NOWHERE in any documentation does it state that traveling with a full FW tank will void any warranty, they changed their tune.
With all that being said, in the 5'r now I don't run with a full tank; usually only 1/3. Partially because of the extra weight, partially because with a large FW tank I don't need it full and lastly because of the incident we had. I am sure the chances of something like that ever happening again are slim, but...
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 09-04-2013, 09:14 AM   #13
Bill_C's Avatar
Travel with a full tank and you have no sloshing problems. I have checked fuel consumption with a full tank and compared to travel with an empty tank. Made no difference in my rig.
DRINK COFFEE--do stupid things faster and with more energy ! Rockwood 5th wheel, Signature Untralite, 8244S
Tow Vehicle: Ram 3500 6.4 litre Hemi.
Bill_C is offline   Reply With Quote
Old 09-04-2013, 04:05 PM   #14
KyDan's Avatar
Tank sensors are just screws in the sides of the tank.
There isn't a float or anything.
Sloshing won't harm the sensors IMO.
KyDan is online now   Reply With Quote
Old 09-04-2013, 04:59 PM   #15
Anacortesians
Because we have some of the best quality residential water in the country (always ranked in the top five), we almost always go out with our 60-gallon tank full. We've come across some really bad-tasting water on some trips.
We use city water at the CG for washing, etc., but always use the on-board supply for drinking. A bit of a nuisance going out and turning the city faucet off when we want the potable tank contents. I'm thinking of adding a solenoid valve to the water hose.
Frank and Eileen
No longer RVers or FR owners
Old 09-04-2013, 05:25 PM   #16
Denver, CO
garbonz's Avatar
On our cross country Walmart overnights we carry a full tank so we can have a light shower every night. We can do about 3 overnights this way if we are careful, then stay at a campground for a day and dump out and replenish. We are going from Denver to Western Ontario with a stop in Elkhart this way, but probably only need two nights maybe. Other than this, I like to have a little fresh water (1/3) of a tank. Our little VCross only carries 44 gallons and has plenty of reserve weight capacity.
2017 Fuse 23T
garbonz is online now   Reply With Quote
Old 09-04-2013, 09:41 PM   #17
kevinC's Avatar
I run my fresh tank full any time we are planning a dry camp trip and have been trouble free. If your fresh tank is in front of you axel here is a Formula to calc tongue weight;
Distance from front axel to point of weight x weight /overall length (front axel to hitch ball, or pin)
2006 T23FBL Wildwood Lite
2009 Ford E-350 Super Duty 5.4L 3.73
kevinC is offline   Reply With Quote
Old 09-04-2013, 09:58 PM   #18
caper's Avatar
If I am reading your post you have your water in the fresh water tank but you also run city water at the CG. My question is do you flush all the lines when you turn off the city water and run the pump for your home water? You will be wasting a lot of your home water to flush the lines of the CG water in order to get water to drink.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 09-07-2013, 02:59 AM   #19
I asked the dealer and they said it is hard on your tank and tie downs to run with a full tank. They recommended running half full but As stated earlier running with a half tank sounds worse with sloshing and kick back when driving. I'll take the risk and run full when I need to, maybe if it's hard on the tanks they should make them better. They should expect people would like convenience in any given situation. Just my 2.0
Long Hual is offline   Reply With Quote
Old 09-08-2013, 09:21 AM   #20
SnoGhost's Avatar
I was surprised to see this is even an issue for discussion. I'm new to owning my own trailer but camped with a truck box camper for years. We always dry camp and the people we camp with always run their trailers with full tanks. No one has ever mentioned having a problem. Some of the points do make sense though. I could see draining the remaining FW tank upon leaving the CG. A tank that is not full is gonna slosh around and why drag all that weight home just to drain it there?
SnoGhost is offline   Reply With Quote
tank
