Old 07-11-2011, 06:32 PM   #11
grhodes50's Avatar
The breaker inside the panel was on when I purchased my tt and I always leave it on. It's just something to check if your going to be using the electric side to your water heater.
Chances are the electric was on, but when you turned on the water heater switch inside the trailer the gas tried to light as well since the water in the tank wasn't heated yet. It didn't light at first because of air in the line. You only need to use this switch when using the gas side to your water heater.
As long as the breaker is on and you turn the black rocker switch on, the electric will heat the water. Just give it 30 minutes or so to get hot.
The rocker switch is a PIA to mess with. That's why I was happy to see that they inculded the electric switch inside my tt along side the gas switch.
Gary & Trish
2018 Nights Camped - 5
Old 07-11-2011, 06:35 PM   #12
(Kim)
Labzy's Avatar
Ok guys.......after reading all of your replies and realizing my initial mistake, this is what I think happened.
1. I did not know that the water heater switch on the control panel in the trailer, is only used for the gas mode.
2. I turned on the WH switch with the pin, located on the outside panel.
3. I did not have any propane on.
4. The 'dsi flt' light came on, NOT because the electric wasn't working, but instead because I had turned on the gas mode also, and it did not have any propane supplying it. ( I heard it clicking )
New question.
Is the 'dsi flt' light only for gas mode? I am assuming this as it is on the panel next to the switch for the gas mode.
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 07-11-2011, 06:40 PM   #13
Yes, it's for gas only. There is no indication inside regarding the electric source for the water heater.
03 Chevrolet Silverado 1500, 5.3 V8, 3.73
06 Rockwood Roo 23SS
Equalizer Hitch
dlhoppe is offline   Reply With Quote
Old 07-11-2011, 06:42 PM   #14
I like that dual switch. Looks like it's an aftermarket item. Now I have to get me one. LOL!
Equalizer Hitch
Old 07-11-2011, 06:50 PM   #15
grhodes50's Avatar
Someone probably does sell the gas/electric switches, however they come standard on Prime Time trailers. They also mount them high up behind a cabinet door where kids can't mess with them.
Another thing I really like, Prime Time also have the digital thermostats as standard equipment.
Gary & Trish
Old 07-11-2011, 07:06 PM   #16
(Kim)
Labzy's Avatar
Ok....I'm still kinda confused
I looked at the breaker panel and I don't understand how to turn that breaker 'on' because it is 'on' already, if it is the one I am looking at.
It shares a breaker with the converter on my panel.
Ok, thank-you all!!!
It was a false alarm then and the light had nothing to do with the electric mode.....
Sorry guys =[
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
Old 07-11-2011, 07:08 PM   #17
Found the Atwood dual switch on eBay for $10.98 shipped.
Atwood Water Heater Dual Switch Panel 91230 | eBay
Equalizer Hitch
Old 07-11-2011, 07:09 PM   #18
Labzy, no worries. That's what this forum is for.
Equalizer Hitch
Old 07-11-2011, 08:30 PM   #19
grhodes50's Avatar
Sorry guys =[
No need to apologize. That's what this forum is for, to help each other. We all started out the same.
I thought I had a water heater problem one time.
I was operating on the electric side and decided I would use the gas. I turned the electric off, then turned on the gas and nothing happened. It didn't try to light and the red light didn't come on. I messed with it for awhile one evening and never did get it to light. The next morning I tried again and it operated as it should!
Through this forum I found out later that since the water was already heated by the electric that the gas didn't need to fire up, so it didn't. The water had cooled down overnight since I didn't turn the electric back on, so it fired up.
Everything was operating as it should, except me!
Gary & Trish
Old 07-11-2011, 08:33 PM   #20
grhodes50's Avatar
Good deal!
Let us know how it works out for you.
Gary & Trish
led pad
