Old 07-11-2011, 07:12 PM   #11
Don't turn the electric heat element on unless you're absolutely sure it has water in it. The bypass valves are easy to figure out if you just study them a little. When the handle is inline with the pipe, it's open. Make sure the valves are set so water flows into and out of the tank.
03 Chevrolet Silverado 1500, 5.3 V8, 3.73
06 Rockwood Roo 23SS
Equalizer Hitch
dlhoppe is offline   Reply With Quote
Old 07-11-2011, 07:13 PM   #12
As Jimh pointed out, the relief valve is a good way to check for water.
Equalizer Hitch
