Old 09-24-2016, 10:29 AM   #1
Dump or hold?
Been having to go camping by myself lately. Wife and kids busy with work and school.
Knowing that the black tank should be dumped only when it's full, is it better to fill it up with fresh water and dump it after every weekend trip, or is it better to wait and let it fill up on its own over the course of several weeks. I use the little blue pouches as tank treatment. Seems like a waste (no pun intended) to dump those so frequently when my own contribution to the blank tank is so little during a weekend. How long can you go without dumping before the situation becomes too putrid and gross?
2016 Salem Cruise Lite 261bhxl
Ram 1500 5.7l Hemi Crew Cab 4wd
gspot01 is offline   Reply With Quote
Old 09-24-2016, 10:37 AM   #2
RSchleder's Avatar
We fill our tank up every 7-8 days and empty when full. If you use it for a weekend and then it sits until the next weekend when it's used again that would be ok in my book. I would, however, dump after the second weekend.
Days camping (2016)----181 days
Days camping (2017) --- 52 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
12 different RV's
RSchleder is offline   Reply With Quote
Old 09-24-2016, 10:40 AM   #3
You don,t say if your moving or stationary! Makes a Big difference in regards to "Tanks" I would NOT Tow with a 1/2-Full Tank! Most of the supports and Tanks are NOT made for This! Do a Search on "Tanks falling out" and most of them are Clear Water think what a MESS you will/might have! Youroo!!
Old 09-24-2016, 10:46 AM   #4
I think it simply depends on a particular lifestyle. I always dump whenever I can, because I don't want to be caught needing to travel on the spur of the moment, or to travel in an emergency with a tankful. Also, I want to be able to have use of the camper at home should my home power or water utilities fail. I would say whatever works is OK. It's certainly always best to dump often and get those solids out, and kill any odors. But some might say you waste water by filling up prior to dumping. To each his own....
It took me so long to post that I didn't realize others had posted also. All valid points.
2011 Sabre Silhouette 260BHS
2006 F-250 6.OL
tinkerreknit is offline   Reply With Quote
Old 09-24-2016, 10:49 AM   #5
Moving. Every weekend or two I'll tow 100 miles or so to the closest (decent) campgrounds. I think I'll take both of your advice. The tank ought to be about1/2 full after every couple trips, so I can just dump after every other trip. Course if the family goes, I'll dump after every trip. Thanks for the advice!
Old 09-24-2016, 12:29 PM   #6
NMWildcat's Avatar
We dump every time we move (unless it was just a quick overnighter). Don't want to haul all that around. So we fill with water and dump. Dont know how hot it is in Arkansas but here in NM I definitely wouldn't want sewage sitting for several weeks if the rig wasn't being used every day.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 09-24-2016, 12:44 PM   #7
Ford Idaho's Avatar
X2
Leaving the tank partially full will allow solids to sink to the bottom of the tank and jelly up.
The water will evaporate out the stack which would then allow the solids to turn into a large unwanted brick.
Old 09-24-2016, 12:51 PM   #8
Canadian Member
itat's Avatar
I tow my TT to the dump station when it's full granted it's no more than a mile. That trip is probably more bumpy than most trips on public roads. I've had to tow mine full down the highway a couple times and haven't had any issues.
If you have the option I would dump sooner but sometimes you don't have a dump facility close by.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer
2016 Ford F-250 XLT SuperCrew, 6.2L, 4x4, 6'9" bed, 3.73
Fondly remembered:
2009 Ford F-150 XLT SuperCrew, 5.4L, 4x4, 5'6" bed (2012 - 2016)
itat is online now   Reply With Quote
