Old 07-27-2013, 07:00 PM   #1
dump valve cables
Has anyone had to attempt to access their dump valves. How do you get to them. Have a 2013 Cedar Creek Cottage 40cfl permanently set up and dealer won't provide service call to repair. Went bad 2 weeks after delivery. Cannot open kitchen gray water valve. Handle pulls out but valve does not open. Do you have to drop belly panel and cut into installation to gain access?
corvairman25 is offline   Reply With Quote
Old 07-27-2013, 08:12 PM   #2
Dave_Monica's Avatar
Unless there's a smaller, access panel to remove, you'll have to take off a 4x8' section od coroplast paneling.
Dave
Old 09-03-2013, 02:28 PM   #3
Ray B's Avatar
How did you fix this? I have a CCK and noticed the same thing on my unit. I'm hoping my cable never breaks.
Ray B is offline   Reply With Quote
Old 09-10-2013, 09:50 AM   #4
Send a message via Yahoo to Jim Spence
If you drop the 1st belly pan right by the main sewer hookup, that will give you access to the black tank valve and a view & clue as to what lays ahead. I came to this site looking for answers and I guess I found them.
My valves are electric ( DRAINMASTER ) and I thought just maybe FR had made improvements !!! Corvairman You're parked permanent get your grey valves open and leave them open Then dump the black tank once a week or as needed, It should be close to full when you dump it. Good luck
05 34CKTS Cedar Creek
swivel wheel trlr
2000 Dodge 5.9 LB QC dually/4x4 manual lockers/BD EXH/ EZ Chip
07 Polaris Sportsman
09 Yamaha V Star 250
Jim Spence is offline   Reply With Quote
