Dump Valves
Have a CC 40CCK. It has Bristol cable dump valves,both 3 inch and 1 1/2 inch. The question I have is can you replace the valves with Valterra valves. I have spoken to many RV techs and it is 50/50 that the bolt holes lineup and that the seals will seal when tighten up. Also has anyone used a 72 inch Valterra cable to connect and operate a Bristol valve. The problem is that Bristol does not sell the cable separate and Valterra does. Again I get different opinions from various RV techs.
Thanks for any info.
