02-21-2013, 05:46 PM
dumping tanks into a residential sewer
hey all, is it possible to dump the tanks into a residential sewer cleanout? by this i mean the big 4" screw on cap that is used to snake out the line going into a septic tank. i have to pull my 22' TT to my job to stay there for 2 weeks, and was hoping to be self contained instead of using the head and shower at the shop... they are kinda nasty!!! I have access to water and 30 amp, just nowhere to dump tanks other than this said cleanout plug.
02-21-2013, 05:55 PM
Great question, I was wondering that myself. Look forward to replies.
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
02-21-2013, 05:56 PM
H2oski
I would think as long as the cleanout connect is lower or below the 4 inch connector on your tt it shouldn't be a problem.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
02-21-2013, 05:58 PM
Yes, absolutely. I've dumped portable waste tanks into mine before, but not my TT. It will work fine.
02-21-2013, 06:03 PM
I believe they even have an adapter at your local building supply store to screw in and hook up your line to. Make sure you keep your black tank valve closed until you need to dump it, you will thank yourself later. Make sure you have enough slope on the line..!
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
02-21-2013, 06:24 PM
I do it all the time, I pull it into the yardn hook it up to the cleanout and drain it. I try to do it before I leave the campground, but it is not always possible.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
02-22-2013, 12:59 AM
I use mine to dump at home. I use a macerator pump since I can't park close to the clean out.
2012 Flagstaff V-Lite 30WFKSS
2015 Ram 2500 Big Horn Mega Cab 4X4
02-22-2013, 07:05 AM
I use our lawn trap all the time to dump and clean out the tanks.
A warning about the "30amp at work"; make SURE it is 110 and not 220.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
02-22-2013, 08:07 AM
The only thing I would caution about is not to use holding tank chems that contain Formaldehyde. Even if you did it would probably be ok, but it stresses a septic system when you do. Especially if it's borderline sized.
Gotta go campin!
02-22-2013, 08:14 AM
It's fine to do that. I do it the whole time we are home which is for 7 months because we live out of our MH.
02-22-2013, 08:35 AM
I use a Sanacon macerator pump that I kept home a Monaco class A coach that I used to have, it pumps it up 10 feet in elevation and I think up to 100 feet through a 3/4 inch garden hose into my 4 inch clean out in the backyard.
I always do a really good shower cleaning and flushing the tanks a day or two later after getting home using the Sanacon pump.
02-22-2013, 09:26 AM
Like Bama Rambler said, if you have a septic tank the blue formaldehyde-based chemicals can pose a problem. Whenever I have done this, I was using the green enzyme-based chemicals, and never had a problem with the septic system. I suspect the green chemicals are actually beneficial to the septic system, much like Rid-X.
Bob & Doris
Roanoke, VA
2009 Toyota Tundra CrewMax 4x4 - 5.7L - 6 Speed Auto - 4.30:1
2013 Rockwood HW296
02-23-2013, 02:27 PM
thanks, ya'll have been so helpful! and yes, the 30A at work is 110. thanks again!!!
