Old 08-10-2016, 01:17 PM   #1
Dynamax black tank flush?
There is a sign under my Dynamax black tank flush inlet that mentions a "fullway termination valve." Is this another name for the valve that has the pull handle to empty the tank?
Also, should I be using a water pressure reducer between the city water hose and the flush valve?
Name:	tank flush.JPG
2017 Dynamax REV 24RB
Delco Bobby is offline   Reply With Quote
Old 08-10-2016, 01:28 PM   #2
brookstone345sa's Avatar
Warning is to make sure your black tank valve is open when flushing. If valve is closed and black tank fills, you have a mess.
However, after flushing with valve open, I close it for a couple of minutes, never leaving the area, and then open valve again , it really flushes out the black tank.
I use pressure gauge type fitting for water line. Too much water pressure can damage interior hoses and fittings. Better safe than sorry.
brookstone345sa is offline   Reply With Quote
Old 08-10-2016, 01:36 PM   #3
Thanks neighbor, sort of.
black, black tank, black tank flush, tank
