Old 12-10-2019, 04:22 PM   #1
E-Pro Water Pump Running
I have a 2019 E Pro, and all of a sudden the water pump started running. My first thought was a leak, but I don't see any leaks. I can shut if off manually, but as soon as I flip the switch it runs again.
I have checked to make sure there is no water running inside, and everything is shut off.
Anyone have an idea?
Thanks.
hatdonuts is offline   Reply With Quote
Old 12-10-2019, 04:34 PM   #2
Commercial Member
ES_FR's Avatar
hatdonuts,
We would be happy to assist you with this question regarding your water pump. Please contact Rayna Dimitroff in our Customer service department through the following personalized and direct link: http://www.forestriverinc.com/Direct...15924368784291.
This direct link is provided for your convenience in order that we may resolve your concerns as quickly as possible. We will strive to respond to you within 24 hours of receiving your correspondence.
Respectfully,
Forest River
ES_FR is offline   Reply With Quote
Old 12-10-2019, 05:15 PM   #3
Trailer Park Supervisor
NJKris's Avatar
If your water tank gets low, the pump will stay on. You must have a pressure loss somewhere. I had leaks in my GeoPro in the water filter bay, all the braided hoses were improperly clamped and loose.
NJKris is offline   Reply With Quote
Old 12-16-2019, 03:12 PM   #4
4 likely possibilities:
  • you are out of water in tank (suction side)
  • you have a vacuum leak (air leaking into suction side)
  • water pump is not building up pressure (pressure side leak)
  • pump not running long enough (pressure side, has to fill water heater if empty)
Did you open a faucet and see if any water is coming out when pump is running? If normal stream of water is coming out, that's an indication of pressure side leak. If faucet spurts, or just has air coming out, it's more likely to be a vacuum side leak.
Fred W
2019 Flagstaff T21TBHW A-frame
pump, water, water pump
