I bought my first camper, not knowing much about them (imagine that lol). I've been reading lately about some of the fifth wheels have insulated and or heated holding tanks. Are these just in fifth wheels? How do they work? Are they actually heated or just in the insulated belly? Is it electric strip type heating or is there a duct from the furnace leading to it?
I'm curious about this because I love to hunt and my camper is not exactly one I can use if it is below freezing outside. My holding tanks are just bare out in the open and my low point pex line drains extend out of the camper belly.
2012 Chevy 3500 Duramax Crew Cab Z71 LTZ SRW
2012 Cherokee Grey Wolf 28BH
2011 F-250 6.2 Gas
2001 F-350 Powerstroke
1995 F-350 7.5L 460
Numerous Ford and New Holland Tractors up to 135hp. Bobcat 773.
they are on all types of campers
basically its a heating pad on the underside of the tank .
most ive seen also have heat tape around the sewer outlets as well .
theres another post on here about low points and what to do with them .
herk why you got to beat me to the post ? don't you have something to fly or something ?
Cool, thanks guys. I've never crawled under a fifth wheel. Are the tanks actually in the belly or are they exposed? My tanks on my camper now are totally exposed.
2011 F-250 6.2 Gas
1995 F-350 7.5L 460
I put heat tape around my low point drains after they froze up once this winter. I was not impressed with how much the pex sticks out, the belly insulation, and my exposed tanks, but then again I have a cheap camper and it isn't a winter camper.
2011 F-250 6.2 Gas
1995 F-350 7.5L 460
Sounds like you might not have the winterizing package. I would think exposed tanks and plumbing would be ... bad ... in winter.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
There's definitely no winter package on it. I don't think they even make one for the camper I have. I had it inside a pole barn that is insulated and has some heat in it. I'm just looking to learn what I could do to this camper to make it ok for the winter or what to look for if I were to buy another camper.
2011 F-250 6.2 Gas
1995 F-350 7.5L 460
Had a lengthy conversation with the guy at our dealership about some issues and I asked him about winter camping. He does a lot of it because he can only get away during winter. Huh...imagine that! Anyway....he said the tank heaters are only "adequate" at best. They run off 12-volt, so be prepared to plug in or have a generator to charge your batteries. They will set some ambient heat from the furnace as well. He said he fills his water tank FULL, as it takes a long time for a full water tank to freeze. He then empties it completely for the trip home. He also said he uses windshield washer fulid with the antifreeze in it to flush his toilet. It won't freeze and won't get "slushy" like the pink RV antifreeze can.
Hope these little tidbits help someone out there....
2012 Rockwood 8293RKSS
So the tanks on your fifth wheel are in the belly and not exposed?
2011 F-250 6.2 Gas
1995 F-350 7.5L 460
How long do you think the 12 volt ones would run while driving before needing to stop and recharge the camper battery? It would be cool if the camper could get power from the hitch plugin to run the tank heaters while driving.
2011 F-250 6.2 Gas
1995 F-350 7.5L 460
Uh, the camper battery does get charged from the tow vehicle if you have a six or seven pin trailer connector. There is enough juice to also run your heaters if they are switched on.
"So the tanks on your fifth wheel are in the belly and not exposed? "
If it has a O/S shower worry about it also. Youroo!!
Ours (2012 Crusader 260RLD) Says it has the winter package in it. We have camped where it got down to 19 one night. Like a couple of ninnys we left the water hose hooked up that night and it froze harder than a brick bat. No trouble with the tanks (grey or otherwise) So I don't know if the tanks are heated but you can see insulation sticking out all underneath the trailer and it's all smooth under there too.In other words you can't see anything when you look under it.
Mine looks like this under the rear. On my next camper I want one with enclosed heated tanks.
2011 F-250 6.2 Gas
1995 F-350 7.5L 460
Huh, what is with the swollen tanks?
Were they full?
That's just the concave shape of them. They've always been that way. Are most flat on the bottom?
2011 F-250 6.2 Gas
1995 F-350 7.5L 460
They do have a shape to them to route the liquid to the dump valve. They are thinner at the end farthest from the valve and thicker in the center at the other end. Kind of "boat hull" shaped.
Your tanks look like a bloated whale found on a beach.
The top one looks OK but the other one is weird looking to me...
2011 F-250 6.2 Gas
1995 F-350 7.5L 460
Can anyone tell me where the on/off switch is located for holding tanks heating.
I have a switch right next to the hot water switch that i can't see what it's for.
Put it on and it lights up red. unit is 8524 RLS 2009. Thanks
