Old 05-05-2014, 05:23 PM   #21
Originally Posted by KyDan View Post
I just switch off the breaker that's labeled WH.
Some units may have other things on that circuit but mine is all alone
so I can use the breaker as an indoor switch.
Don't do it in the camper, but use the breakers to shut the electric heaters on and off in the garage for 14 yrs and they are still working. Do the same on everything else, welders, air compressor, lathe, etc. To me it is a much safer way of knowing they're off. Never had a breaker fail yet, knock on wood.
Old 05-05-2014, 05:33 PM   #22
TURBS's Avatar
All im saying is if that breaker fails from constant switching it could be bad the one time the breaker fails.
I don't give a crap if you've done it and your dad did it and his dad did it for one hundred years without problems.
I wont sacrifice my family's life for 30 minutes worth of work and to trust the breaker works after constant switching for which its not designed for.
Good luck
TURBS
Sabre owners united!
Old 05-05-2014, 05:38 PM   #23
Originally Posted by f1100turbo View Post
...I wont sacrifice my family's life for 30 minutes worth of work and to trust the breaker works after constant switching for which its not designed for...TURBS
What's to break? It either shuts it off or it doesn't. You can always shut the main off , it's right there or unplug the shoreline. Don't see any life threatening issue.
FWIW, I've seen more switches fail than breakers.
To each their own.
Old 05-05-2014, 06:14 PM   #24
Jack of All Trades
RJHuser's Avatar
We have a breaker in the office that controls the daytime lights. Been turned on and off at least 5 times a week, 52 weeks a year, for 40 years (that's about 21,000 operations). Still good, works well, and trips at the proper amperage (just tested the other month or so).
So, should you use a breaker as a switch? Probably not, but you aren't endangering anything. My experience is, short of a hugh amp spike that welds the contacts together, breakers fail open.
Rick
Rick & Debbie; Brandy & Schnoodle (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
RJHuser is offline   Reply With Quote
Old 05-05-2014, 06:25 PM   #25
Rick
Most industrial shops I've been in do it the same way Rick.
Old 05-05-2014, 06:56 PM   #26
davel1971's Avatar
why would it have an "on" and "off" and not just a reset device if it wasn't to be used as a switch? They only cost several bucks a piece so big deal if it fails after 10 years of cycling on and off
David & Lynn
Old 05-05-2014, 07:36 PM   #27
SKnight's Avatar
Good luck
TURBS
To each their own.
Gents,
Y'all sound like an old married couple. You're both right, they're not officially switches, but I've never seen one wear out including the shop I worked in that used breakers as switches for decades.
The way breakers are designed they're supposed to fail open, though anything is possible, whether you mess with it or not.
Old 05-05-2014, 07:43 PM   #28
15 amp breaker at Lowes $3.48. 10 years =$0.35/yr
Shop Square D Homeline 15-Amp Single-Pole Circuit Breaker at Lowes.com
Old 05-06-2014, 06:09 AM   #29
Herk7769's Avatar
Originally Posted by dutch View Post
Hi everyone,
Is there a thread out there on how to bring the outside electric switch on the hotwater tank and wired it inside? Thanks in adavnce.
Water Heater Switch with Power-on Light
HAM CALLSIGN - KC3FFW
Old 05-06-2014, 06:21 AM   #30
KyDan's Avatar
Me too!! And if it fails it's most likely gonna fail open. At the factory where
I worked my entire career, it was rare for a breaker to wear out but it
did happen a few times. All the ones I remember failed open. I don't see
how that is life threatening....
Peace!
Dan & Rita D
Blue Ox WD hitch
electric, heater, water, water heater
