Old 10-18-2010, 10:40 PM   #1
Villa Estate 392FLFB
The_Stuff's Avatar
electric water tank help
I think my hot water tank might be leaking slightly. in the pan under the hot water heater there is a ring of wet at the bottom. I noticed to when we went away for 4 days we had turned it off and there was marks in the bottom of where there had been water. now im sure there shouldnt be any water or wet or marks in the hot water pan. Can someone confirm or deny this?
its a 30 gallon electric GSW (gun shot wound :P )
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 10-19-2010, 07:40 AM   #2
Wanna Be Camper
SaskCampers's Avatar
Maybe your pressure relief valve popped slightly at one time.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 10-19-2010, 09:20 AM   #3
Head Rambler
The Sasks might be right. If your P&T valve isn't plumbed to the outside it could drip a bit. Also if there's a hose spigot for draining it could drip when cooling down. I'd check all the plumbing connections before I suspected the tank itself.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 10-19-2010, 10:57 PM   #4
The_Stuff's Avatar
well it seems its just under the tank. just a wet around the ring. I got some pics but on my other camera. was just outside working on the plumbing and there was a heck of a feline grown that scared me crapless! think it was a cougar!
Old 10-20-2010, 07:31 AM   #5
Head Rambler
If the plumbing comes in the top of the tank one of the fittings could be seeping and running under the skin to the bottom. Or it could be the heating element leaking a bit and running down.
Gotta go campin!
Old 10-20-2010, 07:46 AM   #6
Wanna Be Camper
WOW,
All we get are them thar Coyote's running around here. I think I would have done the same..
And get the pics up when you can, it will make trying to help easier..
John & Deb
Old 10-20-2010, 07:55 AM   #7
Fire Instructor's Avatar
If the pressure relief valve has any debris or gunk under the seal, then it may cause an occasional leak. With the heater off, and the water cooled, pop the pressure relief valve,let it flow a bit to wash out any unwanted gunk. This may allow it to reseat itself. If it continues to leak, it's either defective (easy, low-cost fix) or your temp is set to a higher setting than the relief, which nad be dangerous, because your water will be hot enough to scald.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 10-20-2010, 10:21 AM   #8
The_Stuff's Avatar
lol i know its not set tooo hot. i think ill set a cup under the down spout and see if anything collects in there. makes sense right?
and of course hard to see but there is a little shiny along the bottom. but only at the front.
Old 10-20-2010, 11:36 AM   #9
Head Rambler
I'd pull that cover off and check the element for leakage.
Gotta go campin!
Old 10-24-2010, 07:33 PM   #10
The_Stuff's Avatar
i shoved a plastic drinking cup under the pressure relief valve and yup there is water in there. now how do i "reset" it?
hmmm
"If you notice that after the large amount of hot water is used, the pressure relief valve discharges water, probably you have to install an expansion tank. Water expansion is probably being limited by a backflow-preventer valve or pressure regulator, therefore causing the TPR valve to open. "
