Old 11-26-2013, 11:59 AM   #11
bob213's Avatar
I removed mine completely and use it as an external filter.(Hard to get to where it was mounted.) I didn't like the idea of having the sump full of water while my TT sits in "non use". As an external, I can empty the sump, remove the filter to dry and have less worry about green stuff growing.
bob213 is offline   Reply With Quote
Old 11-26-2013, 01:11 PM   #12
Has any one mentioned the whole filter housing can be removed. Where the fittings are screwed into the housing you can replaced it with a standard 1/2 inch pipe coupling. In our unit you have to crawl in under the bed to get to the filter - didn't take me long to find a solution to remedy that.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 11-26-2013, 01:31 PM   #13
Herk7769's Avatar
Eliminated mine and installed an expansion tank. I use an external in line water filter for silt removal at campgrounds with well water.
Water Worker Accumulator
HAM CALLSIGN - KC3FFW
Old 11-26-2013, 05:19 PM   #14
raspivey's Avatar
I considered doing that last year but rethought the idea. I'm assuming the point is to stop the pump from running every time you open a faucet. After the pressure comes down, wouldn't the pump just run longer once it did come on until the tank pressured back up? Sounds like it would defeat the purpose. Am I missing something here?
Old 11-26-2013, 06:02 PM   #15
Herk7769's Avatar
It keeps the water pressure constant during showers and I get 2-3 good flushes before the pump runs. Yes, it does run longer then (it has to refill the 2 gallon holding tank); but the flushes in the middle of the night don't wake everyone up like when the pump runs every time for a "tinkle."
Old 11-26-2013, 06:26 PM   #16
TURBS's Avatar
Think about this......
How many of us have water filters in our home?
That should answer the question I'd think.
Turbs
Old 11-26-2013, 06:43 PM   #17
Ford Idaho's Avatar
Turbs
I have two filters here at home, only use one on the trailer.
Old 11-26-2013, 06:49 PM   #18
Don't bother flushing after every tinkle. Flush when everyone is awake. It's only tinkle:-)
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 11-26-2013, 06:59 PM   #19
mTn_biKer65's Avatar
Originally Posted by MOD Guy View Post
Ours was a pain in the butt, hard to get to, and took up storage space. I removed it years ago. No problems or issues.
Maybe they learned something as my 2013 Surveyor Select 235 came without the filter which was fine by me. I ended up removing the one from my last trailer and plumbed the space in between.
Still debating whether I want to go the external filter route or not.
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS -
2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
mTn_biKer65 is offline   Reply With Quote
Old 11-26-2013, 08:03 PM   #20
catworker's Avatar
I removed my filter and use it externally now. With the internal filter and housing removed I have room for a drawer. More storage!
2014 Rockwood A194HW
2008 Chevy Colorado 4x4 Crew Cab
catworker is offline   Reply With Quote
water, water filter
