Old 11-26-2013, 09:57 AM   #1
Killingtonrich's Avatar
Eliminate water filter?
Here's a question:
what do you all think about removing and eliminating the filter cartridge from the housing, and just water flow thru their freely? I don't have a need to actually filter the water - this won't hurt the system, will it?
Killingtonrich is offline   Reply With Quote
Old 11-26-2013, 10:02 AM   #2
iluvlcy's Avatar
We removed ours, patched the plumbing and now use external filter. Sure made winterizing easier, I did not like dealing with thing!
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
108 days camped 2013
74 days camped 2014 so far
iluvlcy is offline   Reply With Quote
Old 11-26-2013, 10:22 AM   #3
Batts-toy's Avatar
I use an external filter as well but this approach still reduces pressure in the TT. My concern is if you hook up to a water source without any filter and sand comes through with the water the potential of the sand grit damaging something so I would at minimum have a screen in place. Having said this I prefer a filter be in place that includes activated carbon even at the expense of lower pressure.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 11-26-2013, 10:22 AM   #4
Resident Masshole
force's Avatar
I ran all year w/o the water filter in (basically because I forgot all about putting it back in after de-winterizing)
No apparent harm done.
Tom F.
2013 GMC 2500HD SLT Crew Cab
2013 Rockwood Roo 23SS
Nights camped in 2014: 8
Nights camped in 2013: 30
force is offline   Reply With Quote
Old 11-26-2013, 10:26 AM   #5
Batts-toy's Avatar
Most units have a screen in the hose connector and the water in your tank shouldn't be a problem.
Old 11-26-2013, 10:36 AM   #6
Resident Masshole
force's Avatar
True, mine does, though it's not a very tight mesh so I bet little bits of sand could get through. I'll probably use the filter next season, if for no other reason than it exists.
Tom F.
Old 11-26-2013, 11:00 AM   #7
MOD Guy's Avatar
Ours was a pain in the butt, hard to get to, and took up storage space. I removed it years ago. No problems or issues.
Chuck Roder & Family
'07 Surveyor SV-235RS & '16 Chevy Silverado 2500HD (Gas) Crew Cab
High Springs, FL.
MOD Guy is offline   Reply With Quote
Old 11-26-2013, 11:00 AM   #8
raspivey's Avatar
Both of my trailers had a mesh on the city water connection (I also have one in the faucet side of my hoses) that should catch "most" anything that would plug up a line and a much finer sediment filter inline at the suction side of the pump as well to keep that from getting any junk in it from the tank. Worst case scenario is enough little particles could build up in the aerator screens on the faucets over time and start to restrict flow...easy enough to clean them. The only real purpose of the filter / housing is for drinking water (and removing what very little fine particles managed to slip by) kind of like a Britta filter on your house water. If you're like us and just use the faucets for washing, boiling, and brushing teeth, etc., it's not needed at all really. I keep mine in, but 95%+ of consumed water comes from a bottle so a chlorine / sediment filter really doesn't matter to us.
Old 11-26-2013, 11:14 AM   #9
mark0224's Avatar
It won't hurt anything to not use it but if you don't and you hook up to water that has sulpher, iron or other minerals they can discolor showers, sinks and fixtures. On top of that the smell of sulfer will need chlorine ran through your lines to get rid of it. Water should be filtered before putting it in your tank also if your at a campground, you can't guarantee that water is clear of contaminates.
mark0224 is offline   Reply With Quote
Old 11-26-2013, 11:28 AM   #10
Engineer of Crazy Train
ChooChooMan74's Avatar
Me personally, I feel better having a quality filter. I just have a thing for clean water. If the drawback is a little less pressure, I will live with it. But I am planning to redo mine so that only the cold water to the sinks is filtered.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
water, water filter
