Old 04-16-2016, 12:38 PM   #11
Dishwasher detergent
Originally Posted by bbcutright View Post
Empty Back Water tank is empty but reads 2/3. I have emptied my black water tank flushed it put some Pine Sol in it w/water and get home and it reads 2/3 full. When I open drain connect/valves shut, it dumps out a gallon of goop I'm not wanting to smell or see all over my driveway! What should I look for and why after emptying it still reads 2/3 full and has stuff left in the drain pipe when I get home? The movie RV comes to mind! Ha Ha (not)
I have used dishwasher detergent with excellent results. Fill the tank with fresh water about 1/3 full. Get a bottle of dish washer detergent from the dollar store and add it all to the tank. Drive for a few miles and PRESTO working again. Pine sol makes it smell better but thats about it.
Tropiccafe is offline   Reply With Quote
Old 04-16-2016, 12:56 PM   #12
HikerBob
Originally Posted by bob caldwell View Post
Dipsticks would of been a better choice! Oh wait....a dipstick did design the sensors..
Ha,Ha,Ha - Couldn't have said it any better. The Calgon system works the best of all.
HikerBob is offline   Reply With Quote
Old 04-16-2016, 01:19 PM   #13
Evereddie's Avatar
good one. 👍
Evereddie is online now   Reply With Quote
Old 04-17-2016, 01:37 AM   #14
Bako88fan's Avatar
https://sites.google.com/site/cbruni/
I follow the steps at this link consistently and I find I do not have any problems. If you don't have a clear elbow, I'd suggest investing in one. You can get a Camco model at Walmart for about $8.
http://www.walmart.com/ip/Camco-Sewe...apter/29764318
One more thing: Why are you dumping your tank on your driveway?????
2008 Wildcat 29RLS
2016 Chevy Silverado 2500 HD
4x4 z71 Crew Cab Duramax/Allison
Bako88fan is offline   Reply With Quote
Old 04-17-2016, 07:05 AM   #15
Gold Miner At Heart
Papa-t's Avatar
When using factory tank flush, if you have a clear elbow connector on the sewer hose, leave the valve open and you won't have to worry about overflow'n thru toilet...and you can see the flow and color...you're look'n for clear water!
X2
Papa-t is offline   Reply With Quote
Old 04-17-2016, 07:10 AM   #16
Gold Miner At Heart
Papa-t's Avatar
Baco88fan whatcha doing up at 2:37AM? And where did bbcutright go? I hope the clog didn't get him..
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
Old 04-17-2016, 07:14 AM   #17
Herk7769's Avatar
Since changing out my gray and black tank probes with Horst Miracle Probes, my tank indicators have worked perfectly now for over 4 years.
Horst tank Probe Installation
Horst Mircacle Probes - Get accurate reading on your RV's holding tanks
Note: Other than being a VERY happy user, I have no financial interest in this, or any other product, I have recommended.
Additionally, ALWAYS use lots of water in your black tank in order to assure that the solids stay afloat or do not stick to the bottom of the tank.
NEVER dump unless that tank is almost full. That way there is plenty of water pressure and circulation in the tank to get most of the solids out during the dump process.
Having an "end of mast" shutoff valve also allows one to partially dump the gray tank (with its soapy water) into the black tank for a second black dump to get any of the remaining crude out; just remember to only do the transfer once and for only a minute or so in order to keep water flow from the gray TO the black and not allow the reverse.
I also use the "shielded" (black tank) probe in my gray tanks since the gray/fresh style (coil) seems to attract hair.
ID:	105173   Click image for larger version
Name:	Horst Probe Install 044.jpg
ID:	105174   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 04-17-2016, 09:03 AM   #18
Originally Posted by Herk7769 View Post
Since changing out my gray and black tank probes with Horst Miracle Probes, my tank indicators have worked perfectly now for over 4 years..
X2 on the Horst Miracle Probes.Installed them on my Jayco and they worked great. Haven't put them on the new rig yet since I don't feel like removing the underbelly enclosure. I suspect I'll do it eventually though as they seem to be the only fix for this age old problem that affects all RV owners.
2016 Rockwood Signature Ultralight 8329SS Platinum
2016 GMC Sierra 2500HD Denali Crew Cab Duramax
TXFolkie is offline   Reply With Quote
Old 04-17-2016, 05:05 PM   #19
Bako88fan's Avatar
I don't sleep so 2:37 am is a good time to learn and contribute.
2008 Wildcat 29RLS
Old 04-18-2016, 06:25 AM   #20
Herk7769's Avatar
So, assuming you don't want to replace your probes right away, here is how to clean your tanks so the indicators indicate properly.
1) Flush out tank as best you can with turbo-flush or toilet wand. Close your valves and add 1 pint of Unique's RV-DIGEST_IT to the black and gray tanks. Fill the tanks with cool water to the top.
2) Let sit for a minimum of 3 days; 7 is better.
3) Dump and repeat if needed.
To keep tanks clean and probes working as best as you can.
1) Dump and flush tank with internal washer or toilet wand.
2) Add 5 gallons of water to black tank and add 1 capful of CALGON water SOFTENER (not salt!) and 1 capful liquid laundry detergent.
3) ALWAYS add about 30 seconds of flush water with solids and use RV toilet paper.
3) Wait till tank is full (or near full) before repeating above.
You will dump more often, but your black tank will be clean and function properly. As a plus your tanks will never smell.
http://www.amazon.com/Unique-Natural...s=rv+digest+it
http://www.amazon.com/Camco-40074-Fl...s=tank+wand+rv
http://www.amazon.com/Camco-40126-To...=RV+tank+flush
http://www.amazon.com/Septic-Toilet-...nk+flush&psc=1
tank, water, water tank
