Old 07-17-2013, 10:00 AM   #11
jevanb's Avatar
SS screwed mine on. Got sick of stealing everyone elses after I lost mine.
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 07-17-2013, 10:23 AM   #12
rotorhead1250's Avatar
I didn't know they came off either until my sewer hose was draggin 20 feet behind me! I drilled one small hole through the bumper and into each cap and insert a SS sheet metal screw in it. I still store my dump hose in the bumper.
Matt & Kathie
2017 Grey Wolf 27RR
rotorhead1250 is offline   Reply With Quote
Old 07-17-2013, 10:24 AM   #13
The WirthCo bumper caps look like a cheap, easy, no-drill solution. I will have to pick up a pair.
Thanks everyone.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 07-17-2013, 10:25 AM   #14
Oh, for the people who don't store the hose in your bumper, where do you store it? Seems awful messy to put anywhere else.
Old 07-17-2013, 10:29 AM   #15
Fulltime family RVer
Originally I used a pair of rubber maid totes for all of my sewer stuff.
Now I use a pair of vinyl fence posts with rain gutters as pull out trays. I keep them in the bed of my truck. I'll eventually mount them under the camper- but they fit nicely along side of my hitch.
ependydad is online now   Reply With Quote
Old 07-17-2013, 10:30 AM   #16
Camper Less Camping
Cajun Po-Boy's Avatar
5" square white vinyl fence post with end caps mounted under my front storage bay area...best mod I could have done
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 07-17-2013, 11:28 AM   #17
fivecodys's Avatar
We have owned two different travel trailers and I mad the same mod to both.
I went to the hardware store and bought two 1/4"x6" bolts.
These bolts had about 1-1/2" of threads on them.
I cut them where the threads ended and drill a small hole all the way through about 1/4" from the end.
With the black rubber caps pressed into the ends of the bumper, I drilled a 5/16" hole through the bumper and through the flange of the caps.
The 1/4" pin I made pushes down through both and I stick a little spring pin through the hole so the pin can't fall out.
It has worked perfectly.
One of the previous posts used wire for the pin. I like that idea too.
Bill
2009 Flagstaff 8528 RKSS
2007 Toyota Tundra DC 5.7L V8
Pullrite Superglide 14K
Air Lift 5000
Prodigy Brake Controller
"I've got a mind like a steele.. a......a steele......um.....uh...... what's that thing called again?
fivecodys is offline   Reply With Quote
Old 07-17-2013, 06:20 PM   #18
rip
rip's Avatar
end-cap skewers
This is low-skill, cheap and simple...
Go to 99-cent store, pick up a set of fondue skewers.
Drill appropriate size holes thru top/bottom bumper and nylon end-caps.
Cut two skewers from the set to 6".
Attach a bungee-wrap to each skewer.
Insert your new "end-cap skewers".
Hey now, your end-caps are secure, and that skewer won't come out and puncture a tire behind you. Now be nice and share the left over skewers from the set with your camping friends, or, well, cook something nice on the pit.
Ray
+ 2013 Rockwood Windjammer 2809W
+ 2008 GMC Sierra Crew Z71
+ 2002 Ford F-250 7.3L 4X4
rip is offline   Reply With Quote
Old 07-17-2013, 06:29 PM   #19
Herk7769's Avatar
Never gonna happen!
HAM CALLSIGN - KC3FFW
Old 07-17-2013, 06:30 PM   #20
KyDan's Avatar
End cap skewers-
What a great simple solution!!
Good photo too.
My -minor- problem is I can't get at my bumper from 2 opposite sides
on one end.
I can drill the back and the bottom but not the top or the front so my
holes are 90 deg apart on that end rather than 180 deg on opposite sides.
On the other end I can drill top and bottom.
I made it work anyway.....
I believe on rough roads the sewer hose actually slides back and forth
inside the bumper and it WILL eventually nudge out the end cap if you
don't secure it somehow.
Peace!
Dan & Rita D
Blue Ox WD hitch
