Old 07-17-2013, 06:36 PM   #21
Here's my sewer hose holder, 5" vinyl post with rain gutter. Held to frame with SS bolts with fender washers clamped over the top of the frame web. Two on the inside, two on the outside of the frame rail, so 4 on each side of the camper. For each bolt you need 3 fender washers: one inside the vinyl post, one on top of the frame rail, and the 3rd you cut in half and sandwich between the post and the top fender washer (makes up for the thickness of the frame rail.
Name:	Sewer Hose #1.jpg
ID:	35586   Click image for larger version
Name:	Sewer Hose #2.jpg
ID:	35587   Click image for larger version
Name:	Sewer Hose #3.jpg
ID:	35588   Click image for larger version
Name:	Sewer Hose #4.jpg
ID:	35589   Click image for larger version
Name:	Sewer Hose #5.jpg
rockfordroo is online now   Reply With Quote
Old 07-17-2013, 06:51 PM   #22
I got the post and end caps at Home Depot and the rain gutter and gutter ends at Lowe's. Also, I didn't really say it above, but ALL the hardware needs to be SS (bolts, nuts, fender washers, eye bolts, etc).
Old 07-17-2013, 06:51 PM   #23
Terier's Avatar
Originally Posted by Capt. Mike View Post
WirthCo 30000 Black RV Locking Bumper Plug $6.56 each at amazon.com and probably available at other places, too. Put them in, then push in the center of the cap to expand the edges and lock them in place. My OEM caps kept coming out, too, but these have eliminated the problem.
I switched to this type too. 2-1/2 years later haven't lost a cap since switching.
Old 07-17-2013, 06:55 PM   #24
NELA
Weezer's Avatar
DH solved our problem with this by wrapping doubled backed tape (he uses it for golf club grips) once around the inner "fins" then tapped them in with a rubber hammer.
Of course, we don't use the bumper to store anything in.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 07-17-2013, 08:37 PM   #25
Camper Less Camping
Cajun Po-Boy's Avatar
Originally Posted by rip View Post
This is low-skill, cheap and simple...
Go to 99-cent store, pick up a set of fondue skewers.
Drill appropriate size holes thru top/bottom bumper and nylon end-caps.
Cut two skewers from the set to 6".
Attach a bungee-wrap to each skewer.
Insert your new "end-cap skewers".
Hey now, your end-caps are secure, and that skewer won't come out and puncture a tire behind you. Now be nice and share the left over skewers from the set with your camping friends, or, well, cook something nice on the pit.
Great easy & simple solution!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 07-17-2013, 08:40 PM   #26
Don't like putting a wet stinky slinky in a 4" square carbon steel tube that can't be painted or inspected very well.
Old 07-17-2013, 08:53 PM   #27
NELA
Weezer's Avatar
Originally Posted by gmacklem View Post
Oh, for the people who don't store the hose in your bumper, where do you store it? Seems awful messy to put anywhere else.
We bought a semi-clear square plastic box about six inches tall to store ours in. The box goes into the belly storage bay.
Old 07-17-2013, 09:08 PM   #28
dcheatwood's Avatar
Ok, this is a plumbing related question, I guess. The end caps on the rear bumper come loose while I am moving. I am afraid that sooner or later one will come off and the sewer hose will come out on the highway. It is a new trailer and the hose actually fits pretty snug so I am not sure how the end caps are coming loose. Is there a better method for securing the caps to the bumpers?
Drill a small (1/8") hole thru top and bottom of bumper and edge of caps. Stick a cheap shis-ka-bob skewer thru the holes and snip it off about 2" below the bottom. Really cheap, quick fix.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 07-18-2013, 07:46 AM   #29
Very cool setup. Saw a camper at one campground that was using the vinyl gutter to keep the slinky from bulging out. Will have to check into that as well.
Thanks everyone for the advice, I have ordered a pair of the WirthCo bumper caps.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 07-18-2013, 07:56 AM   #30
Gives the shis-ka-bobs more flavor too! At least that one.
