Old 11-11-2013, 07:23 AM   #1
Eternabond tape to seal water tank
Does anyone have experience using Eternabond tape to seal a crack in a fresh water tank?? Our Forest River is a couple months out of warranty and has a crack along one of the manufacturing seams. No luck with the dealer. I have read about welding the seam, but no one in the area does that type of work. Of course, the dealer just wants to replace the tank.
lonewolf465 is offline   Reply With Quote
Old 11-11-2013, 07:30 AM   #2
Witch Doctor's Avatar
Why don't you try that FLEX SEAL in a can, they say it will stick to anything and seal it 100%. I'm talking about that stuff advertized on TV that seals the bottom of the boat, either that or try an epoxy.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-11-2013, 08:28 AM   #3
I don't think eternabond would work.
Old 11-11-2013, 08:31 AM   #4
DDC
DDC's Avatar
You need to be aware of how toxic anything you use is, remember it is in contact with consumable water.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 11-11-2013, 08:36 AM   #5
I think if he roughed it up real good with sandpaper and wiped it down with acetone, it might work. Worth a try anyway.
Old 11-11-2013, 08:48 AM   #6
Crusader's Avatar
I have a friend that had his fresh water tank welded. It works ! Check the yellow pages for a private R.V. repair shop. The local dealer told him they donít weld. He found a private shop that had the machine.
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 11-11-2013, 08:51 AM   #7
DAISY BOYKIN's Avatar
Out of warranty----------------
Even tho your Forest River product is out of warranty by a couple of months, I would still contact Forest River (not the dealer) about the fresh water tank
being covered. You may just get a free tank but no free labor!! You have nothing to lose. If it was the factory rally, it would be free including installation.
Good Luck
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 11-11-2013, 09:19 AM   #8
TURBS's Avatar
Here's what you need.
http://www.permatex.com/products-2/p...air-kit-detail
I use it all the time with 100% success rate.
Don't fool with what "might work".
Do it right the first time.
Turbs
Old 11-11-2013, 09:22 AM   #9
TURBS's Avatar
In use for 2 years with cleaning solvent in it.
Albeit we used the fuel tank version repair kit.
Turbs
Old 11-11-2013, 09:28 AM   #10
I agree go with getting it welded. What that involves is actually remelting the plastic in a controlled enviroment. If the tank is polypropolene material, welding is the only fix. The problem with some plastics is adhesion properties because wax is part of the plastics makeup. But PVC,ABS, Acrylics can be mended with a product I have used sucsessfully. But I go with getting it welded if FR doesn't goodwill it out of warranty for you.
2012WhiteSolera is offline   Reply With Quote
eternabond, tank, water, water tank
