Old 11-08-2017, 05:52 PM   #1
Faulty Toilet
Well, tomorrow I'll be pulling the toilet out. Went to winterize today and everything was fine until I tired to flush the toilet. No water coming out. There was "pink" up to the water valve and the flush pedal operated, and the seal held water in the bowl, but something's broken. So, it goes to my shop in the Am to find out what? Yay me
uchytil is offline   Reply With Quote
Old 11-11-2017, 09:39 AM   #2
SeaDog's Avatar
Pulling the toilet is easy enough to do, might take more time to find the repair parts.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 11-11-2017, 09:46 AM   #3
Did you pull the line off the flush valve and look for crud?
There is typically a 'filter/screen' inside where the line goes on.
Often times holding your cell phone in tight spaces will allow you to see back in where your head wont fit.
The screen is cleanable with a little compressed air.
Name:	toilet valve.png
Days Camped: '16=46 '17=30 '18=51 '19=32
Old 11-11-2017, 10:22 AM   #4
bubbles's Avatar
Just a note. 5picker is correct but if water will not pass through neither will compressed air. Typically the cleanout (without pulling the valve) can be done with a toothpick or similar working the crud back out the water connection. The screen is not removable it is an integral plastic screen. Be sure and relieve pressure by turning off water supply and opening a faucet or two (cold side). Paper towels should be sufficient to mop up excess at the valve site. This procedure is predicated upon your toilet being a Dometic model 300 (310/320) series toilet. Just speaking from experience with this issue.
Old 11-11-2017, 10:59 AM   #5
Bubbles is correct about the water/air flow.
I meant (and should have specified) to pull the supply line and clean the screen from the supply side with a little compressed air. I've successfully done that without blowing it further into the screen.
