Bought a 2007 FR Wildcat. Winterized it and discovered it had an anode rod. So, I'm assuming it's a Suburban water heater. Does anyone know the size of anode rod needed? I can't find anyone who knows (not even service tech!)
If it's a Suburban like you say, it takes a 1-1/16" socket and at least a 6" extension and a ratchet or breaker bar to remove it. Make sure you flip the lever at the top to release the pressure. Stand to one side so you don't get wet. You will need some Teflon tape to wrap the threads on the new one when you put it in.
If you buy online buy two. You will always notice you need to replace the anode rod when your local dealer is out of them and you have the old one out. Unused they last forever.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Suburban recommends Magnesium or Aluminum - right out of the Suburban Anode replacement manual. It says Magnesium should last over a year - if it does not, they recommend Aluminum as it reacts slower and should only be used where a Magnesium anode does not last one year.
If you have never had it out; you should examine it using this chart.
It may just need to be flushed out and put right back in (using Teflon tape or Teflon pipe dope, of course).
The anode on the red tool box is good to put back in.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
