Old 06-15-2016, 03:16 PM   #41
Pickin' & Campin'
Originally Posted by Shanks12 View Post
And on an un-related note, I noticed this in the bathroom. Would you be concerned. I'm guessing this is an easy way for water to get inside. not sure how long it has been this way, but we have had a lot of rain the past few days and I don't see any leaks. The other side has the seal bubbled up as well. In the picture behind the crank it is actually broken in half (the seal).
The vent lid does have a lip that extends down beyond where the seal contact point is so you still have some protection in the rain. It probably won't seal going down the road though with the seal bubbled up like that.
Sometimes that seal will swell (the sun as well as roof treatment chemicals sometimes don't always play well with other materials) and I've been able to slip it back in place on the metal lip of the vent housing and cut off the excess.
As mentioned vent covers will help but you are going to need to address the seal regardless.
I'd have more concern about that big @s$ bug on the vent screen!
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 06-15-2016, 05:31 PM   #42
This is a little off the deep end but... With some VERY creative plumbing and some valve adjustments. You could use the on board pump to draw outside water into holding tank. I think I would try it if it were mine. Biggest problem is accessing valves when needed that may be to much to overcome.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is online now   Reply With Quote
Old 06-15-2016, 06:12 PM   #43
Settled on buying a water pump
Tried many solutions including building a platform so that I could set my jug higher than the fresh water tank input. After research I settled on what I liked best. I went out and bought a water pump that was the exact make and model of the one I have in my trailer. In that way if I have a failure I have a back-up. Don't just go buy any old pump and hook it up to any old hose to save money. Unless you don't drink your water your pump needs to be certified as a potable water pump and so does the hose. You won't get one at Harbor Freight (already tried that route). The pump I had was a Shurflo (pretty common in RV water pumps) Then I wired up the electric so I could run it off my car cigarette lighter. Tried it last week and it did a great job pulling water from jug...no more holding and lifting...dropping jugs....break water spouts etc. Good luck!
asherwood is offline   Reply With Quote
Old 06-17-2016, 12:07 PM   #44
So I just purchased a cover for the vent. Will be here tomorrow so I'll get that installed asap. Then figure out how to get that issue fixed. Not sure if its an easy/cheap fix then i'll do it myself vs trying to take it in for warranty.
Question on the pump. I have found these two on Amazon:
Seaflo 12V DC 1.2 GPM 35 PSI 21-Series Diaphragm Water Pressure Pump for Caravan/RV/Boat/Marine = $28.61 - 283 Reviews 4.3 Stars
Amarine-made 12v Water Pressure Diaphragm Pump 4.3 L/min 1.1 GPM 35 PSI - Caravan/rv/boat/marine = $18.99 - 28 Reviews 4.1 Stars
For hook up, running a cable to the battery on the camper or the truck would mean running at least a 30ft cable which seems that it may be a lot of trouble - maybe not
We just bought my son a 12v F150 Power Wheels the other weekend. Could I use that battery to power the pump? I suppose I would just need to touch the correct terminals. Would it hurt his battery? Should I get one dedicated to this instead?
-- 2017 Ford F150 FX4/Lariat
-- 3.5L EcoBoost w/ 10 Speed & Max Tow
-- 2016 Salem Hemisphere Lite 27BH
Shanks12 is offline   Reply With Quote
Old 06-17-2016, 05:08 PM   #45
We have a hemisphere also our solution was buying a Shurflo 4008 pump 12v 3gpm. There are several different small pumps that would work but for me personally I wanted something certified for potable water and these pumps are truly "self-priming run dry" pumps. It has 1/2 inch male threads on the intake and outflow and came with barbed connectors to fit hoses. Not wanting to cut the end of one of my potable water hoses I bought a 1/2" female to 3/4" male fitting so I could connect my white hose directly to the pumpon the discharge end then bought a 5' piece of food grade 1/2" I D hose for the intake and attatched the barbed connector to it. For power I bought a 7 pin plug and wired the pump to it that way I can have the jugs of water and pump in the bed of truck run the white hose to the fresh water fill. It works vwry well. One thing if you're to go that route the 7 pin plug black is pos white is the ground on that particular pump(others maybe different) red is pos black is the ground.
Bear fans is offline   Reply With Quote
Old 06-21-2016, 10:46 AM   #46
chideock's Avatar
Just found out that my brand new Sunseeker will not gravity feed to the fresh water tank. We do have a gravity/fresh water fill which works fine with a hose connected to the house to fill the onboard tank. Can not fill onboard tank by pouring water from a jug. The fill hose goes up to the tank!!!
Will have to buy a pump!!!!
2016 Sunseeker 3010ds towing a 2013 Ford Explorer 3.5L AWD.
chideock is offline   Reply With Quote
Old 06-21-2016, 10:52 AM   #47
Ford Idaho's Avatar
I rather like the pump option, no lifting of water jugs, wet shoes and such.
Once you get the pump wired it is pretty much "plug N play"
Besides, the lite does not have a gravity spout so a pump is about it.
Old 06-21-2016, 03:15 PM   #48
Are these designed for potable water? Usually the cheaper ones aren't but you may have found yourself a deal.
Old 06-21-2016, 03:19 PM   #49
Oh, sorry...I was talking about the Seaflo and the Amarine that you have listed.
Old 06-21-2016, 03:52 PM   #50
rollin with the rudgies's Avatar
water pump
when we dry camp I take along some 7.5 gallon water tanks and a wayne PC2 115v 340 GPH portable water transfer pump which I run on the generator as needed. The input side has a short hose that i feed into the portable water tank and the out put I screw onto my fresh water tank fill up ( not gravity fed) using my regular white fresh water hose. I can usually fill up to 3/4 of my fresh water tank (using multiple 7.5 gallon water tanks) but then the pump does not have the power to fill the last 1/4. I purchased the pump and the tanks off amazon and they do the job well.
I hope this helps
Regards
rollin with the rudgies is offline   Reply With Quote
fresh water, water
