Old 06-14-2016, 08:52 AM   #1
Filling Fresh Water Without Gravity Feed
Hey everyone!
I am wondering if this would work to pump out water from a 5gal jug into my camper. It doesn't have a gravity feed, so I am wondering if this auto-siphon would do the trick.
Siphon outlet 5/16"
Tube ID 5/16"
Tube OD 7/16"
I would need a way to connect the tubing to a standard garden hose connector so that it works with the camper. This seems to be an easy/in-expensive method - But would it actually work?
If so, i'm trying to find which parts I would need to make the connection. Any help?
-- 2017 Ford F150 FX4/Lariat
-- 3.5L EcoBoost w/ 10 Speed & Max Tow
-- 2016 Salem Hemisphere Lite 27BH
Shanks12 is offline   Reply With Quote
Old 06-14-2016, 09:00 AM   #2
SeaDog's Avatar
I have never heard of a TT that doesn't have gravity feed for filling the potable water tank. Your rig if its the one pictured is newer it should have a fresh water fill. There are posts that tell how to use the winterizing fitting for getting potable water to your rig.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-14-2016, 09:09 AM   #3
clr
I also have never seen any RV that did not have a gravity feed fresh water fill. I would spend some time looking for the fill, It may be behind a door and have a cap over the fill but there should be a fill. Also if this is truly a siphon and not a pump of some type I see no way this would work. A siphon has to have the output lower than the input. So you would have to lift the water jug above the fresh water tank input. This does not sound very doable to me.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 06-14-2016, 09:18 AM   #4
Mr. Dan's Avatar
There are posts on this site about RVs with no gravity feed fresh water fill. They have a city hose connection with a valve to switch between the unit's piped water system and the FW tank. SOB unit next to me this weekend had that set-up. Guest staying with owner asked me to help decipher the diagrams to get water in the unit without using the pump. I couldn't figure it out!
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 55; booked = 20
Old 06-14-2016, 09:28 AM   #5
Yeah, I have walked around the camper more times than I can count to try and search for one. I've even had my brother in law look as well to make sure I wasn't missing something. But all I am seeing is a Fresh Water fill on the back and a city water connection. No where do use a funnel and dump in like my last camper.
I was reading on the forum and others mentioned that campers with this setup need some sort of hand or electric pump to get the job done.
My thinking was to set the jug on the rear bumper and then use the siphon. I believe with that the fresh water fill would be lower than the jug/top of siphon.
I would look into using the camper pump, but it's under the rear bunk so I would have to remove everything from the bed, remove the mattres, and then lift up the plywood to get to it all while ducking below the top bunk.
I figured this may be an easier and inexpensive option. I've looked at some of the hand pumps for kayaks but I'm not sure the diameters of the pump would fit in my jug.
Old 06-14-2016, 09:33 AM   #6
What is this "fresh water fill on the back" you are speaking of?
Is it a standard 'city water' hose type of connection?
Days Camped: '16=46 '17=30 '18=51 '19=32
Old 06-14-2016, 09:40 AM   #7
Correct. I was looking through my pictures and I don't have a good one to show you and not near my camper at the time. I'll search Google to see if I can find one. But yeah, it's the screw in a garden hose type. One for Fresh Water and one City Water
Old 06-14-2016, 09:45 AM   #8
So hook your hose up to the fresh water connection and it should fill your tank.
2019 Silverado 1500
No camper, currently
polishdon is offline   Reply With Quote
Old 06-14-2016, 10:15 AM   #9
Are you saying from the jug? Or are you meaning from a filling station?
Old 06-14-2016, 10:24 AM   #10
You are going to have to fashion some kind of an adapter to go from the hand pump hose to your fresh fill connection. Stick the pump in the jug, screw the hose/adapter to the fill connection and pump into your tank.
Alternately, if the hose on the hand pump is small enough to slide INSIDE the fill connection (you may have to remove a small washer/screen in the connection) just slide the hose inside and pump away.
fresh water, water
