Old 10-08-2015, 05:47 PM   #11
Originally Posted by BillyBass View Post
I have a half of 55 gallon drum back up to spigot have a 25 ft hose fill it up then back by my water intake then I have a small pump I plug it in hook the hose to it then walk away .it fill up slow which pushes out all the air and I only have to fill it up once after the first one
X2
2014 cedar creek 36ckts
2014 Chevy 3500 1 ton crew cab 4x4 long bed.
cfiowa is offline   Reply With Quote
Old 10-09-2015, 03:10 AM   #12
Do you have an outdoor shower near your Fresh Water than fill port??
In my case, I can connect ~ 5 ft tube to the antifreeze fill port and dip it into a filled 6 gal jug on the ground. I then remove the shower head of the nearby outdoor shower and stick the shower hose end into the fill port. The water is then pumped through the camper and into the FW tank.
Obviously this would only works if you have a similar setup.
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline   Reply With Quote
Old 10-09-2015, 12:27 PM   #13
Originally Posted by Ridenfun View Post
I use the collapsible water 'bags" commonly sold for more basic camping. They fill easily, use a smaller hose that attaches to the spout. Since they collapse while emptying, no air lock. And when empty, I crush them then close the "faucet spout", so they stay flat, to save space. They are available in different sizes too, so can use several smaller ones to limit the weight lifting it to above the tank inlet.
I use those 5 gallon "bags" and love them. I have a valve that switches between a short hose or my main water tank. When I change the valve I place the short hose into the bag (jug) then turn on my water pump. This pumps the water from the jug instead of the fw tank.
And yes I know the water hose was kinked, I fixed it.
Jim
ID:	91054   Click image for larger version
ID:	91055   Click image for larger version
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 10-10-2015, 11:58 AM   #14
I don't have an outdoor shower but use the same technique using the bathroom sink. I replace the aerator with a hose adapter, connect my water hose to it and the other end of the water hose to the fresh water fill port. I switch the system over to winterize mode and place the winterize hose into a 5gal jug of water.
When the pump is turned on with the faucet open, water is drawn from the jug by the pump, goes through the faucet and hose then into the fresh water tank. I also make sure, when dewinterizing, to clear out the winterizing hose so no antifreeze ends up in the fresh water tank.
Phil
pmsherman is offline   Reply With Quote
Old 10-10-2015, 12:07 PM   #15
BooBoo23's Avatar
You can get a pump that fits on a power drill. If you have cordless drill so much the better. From Harbor Freight or Northern Tool
Home
<LI class=product>All Purpose Drill Powered Pump
Double click on above image to view full picture
Drill Master - item#34302
1.3
(44)
Read 44 Reviews
Write a Review
Uses your drill to drain water quickly with this drill pump
Only: $3.99
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
Old 10-10-2015, 12:41 PM   #16
Anacortesians
You can pressure-fill the FW tank using your white water hose on a home or other fresh water faucet with a threaded body. Attach the RV end to the FW tank's pressure fill port and turn the faucet on.
Since we have one of the top 5 city systems in the country for water quality, we always left home with a full FW tank. I used one of the outside faucets near to where the MH was parked at home. If we used up the FW tank contents on a trip and a CG had good water, I'd do the same. IIRC, the FW tank was 40 gallons. I wasn't bothered about an extra 320 pounds since we were way under max GW on a typical trip.
Frank and Eileen
No longer RVers or FR owners
Old 10-10-2015, 01:02 PM   #17
Where did you find a 55 gallon drum that was clean? I would be a little concerned about what was in the drum.
Jim
George Bernard Shaw
Old 10-10-2015, 01:13 PM   #18
You got me thinking. I remember seeing someone with a large trash can. He used trash bag in it and changed it each time he filled the can so it was always clean. He then used a drill pump like you to top off his fw tank.
Jim
George Bernard Shaw
Old 10-10-2015, 03:45 PM   #19
I use collapsible bottle put a piece of tubing on and put a table and stool on top an let gravity do the work. I don't have to hold the bottle.
NorSnrub is offline   Reply With Quote
Old 10-11-2015, 12:37 PM   #20
BillyBass's Avatar
drum
Jim
I got a plastic one .What I did cut the top off then i scrub it out with soap and water .When we camp we don't drink the water we take bottle water for drinking and cooking.All we use it for is showering and the toilet and what little dishes we have we use plastic.
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites
2015 16 nites
BillyBass is offline   Reply With Quote
tank, water, water tank
