Old 01-26-2016, 07:04 AM   #11
Mr. Dan's Avatar
Filling water tank question?
Originally Posted by VizJedi View Post
Just curious, but is the black knob above the black valves in the pic above the antifreeze port?
j
I believe it is. It looks like a black version of my white antifreeze "sucker" but I've never seen a panel like this pic. And rather than a knob, it's a female threaded connection.
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 01-26-2016, 09:03 AM   #12
VizJedi's Avatar
Originally Posted by Mr. Dan View Post
I believe it is... it's a female threaded connection.
Thanks,
This one is a cap and plug on a male threaded connection. I suspect there is a "hose kit" to make this work. I'm sure Home Depot has everything I need to make my own "kit".
I just wish the manuals were a little more specific to the brand/model. The general FR manual doesn't address my panel at all.
j
2016 Coachmen Chaparral 390QSMB
2011 F350- CC, DRW, LB, PSD
2016 nights camped: 40
2017 nights camped: 16
2017 nights reserved: 30
VizJedi is offline   Reply With Quote
Old 01-26-2016, 09:09 AM   #13
AquaMan's Avatar
One is a tank fill, the other is probably your city water. Most tank flushes look the same, but are black and somewhat separated from fresh water.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 01-26-2016, 09:09 AM   #14
ov845's Avatar
My belief is threaded outside - winterizing port, threaded inside - city or flush ports, no threads fresh water fill. Unfortunately all mine are black ( but labeled ),
ov845 is offline   Reply With Quote
Old 01-26-2016, 09:10 AM   #15
AquaMan's Avatar
Sent (I think)
That's probably not a knob, but the cap on the end of a hose. Give it a pull.
Old 01-26-2016, 12:41 PM   #16
X2 Mr.Dan & Aquaman, that should be his antifreeze suction hose with a black cap. Just pull it out and you should have a hose long enough to drop in a bottle of AF.
As far as the two water inlets, mine on my 2014 Heritage Glen has two female threaded inlets, one is for city water and the other (yes it is threaded too) is for my fresh tank fill. But I am amazed at the lack of labeling in this unit. Usually I see it labeled wrong, but at least it's labeled. My black tank flush is also identical and nearby, but it is a black fitting as opposed to the white fittings. In answer to the OP, hook em' up and see what happens!!
Gregg & Denise
2006 F-350 CC LB 6.0 Diesel 4x4 DRW
2014 Heritage Glen 366bh
2015 Camping---"162 Nights"
2016--Moved in camper 11/2015 while
getting ready to sell sticks-N-bricks
PIGMAN is offline   Reply With Quote
Old 01-26-2016, 12:53 PM   #17
The picture the OP put up in post 4 shows two gravity fills with no threaded connection. You can see the screened ports for the vent lines on each one. One has to be for the fresh tank. Is it possible his unit has two fresh tanks? I added a tank on one of my hybrids and had two fills like that, but I have never seen one from the factory. And with two tanks you need a 3 way valve somewhere on the pump suction line.
Maybe they cut the 3" hole for it in the wrong place, and then just stuck an extra fill port in to fill the hole ? That would not surprise me.
Why not look underneath, or open up the access inside, and see whats connected to them and where it go's?
Mr Havercamp is offline   Reply With Quote
Old 01-26-2016, 01:06 PM   #18
AquaMan's Avatar
Having 2 tanks makes sense, since he said he had 80 gallons of fresh water. The biggest tank I've seen has been 60-65 gallons.
Old 01-26-2016, 01:11 PM   #19
ov845's Avatar
How big is your fresh water tank? You must have a separate vent tube when filling the tank the air has to escape somewhere.
Old 01-26-2016, 01:16 PM   #20
AquaMan's Avatar
My Sierra had a screw connection for fresh water tank. The vent was located underneath next to the tank drain.
tank, water, water tank
