Old 01-27-2016, 03:01 PM   #31
My TT has two as well. One is to fill the fresh tank and the other is city water bypass. They are located one above the other as you described. Bypass is threaded and the tank fillis not.
wboglejr is offline   Reply With Quote
Old 01-27-2016, 03:18 PM   #32
Mr. Dan's Avatar
I wonder why they call it "city water bypass." What are they bypassing?
If you'll look at the pic in post 27, you'll see his city water hook-up (threaded connection) to the right of this pair of caps (which don't appear to be female threaded).
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 01-27-2016, 03:29 PM   #33
Pickin' & Campin'
Originally Posted by RipSteele View Post
Finally had time to take a picture and read the labels. I feel stupid now
Why do you feel stupid?
I'm still scratching my head!
They both look like fresh water fill ports and both the labels say exactly the same thing. (I believe both caps do as well)
Did I miss something in your photo pointing to the definitive as to whether it has two tanks or not?
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 01-27-2016, 05:43 PM   #34
I feel stupid for the fact I can't figure out why they would put two fill tubes on here. I do know now it has two tanks with two separate drains. I'm not sure yet how both are connected to one another.
RipSteele is offline   Reply With Quote
Old 01-31-2016, 09:37 PM   #35
gmann55's Avatar
They call it bypass because it bypasses the holding tank and distributes the water directly Thur the the water system and also bypasses the water pump!
gmann55 is offline   Reply With Quote
Old 01-31-2016, 11:25 PM   #36
You just through me a loop with that answer. Your saying I have a tank that I can fill with water and it will bypass everything? This is not a city water connection but two fill tubes
tank, water, water tank
