Old 04-16-2016, 07:44 AM   #1
Lost Vermonters's Avatar
Filter housing
Trying to de winterize. Filter housing has no filter but full of antifreeze. Even with the supplied tool I cannot loosen the housing to remove pink stuff or install new filter.
Any idea?
After 17 years gone - Finally moved back to Vermont 2016.
2015 Microlite 21 FBRS
Silverado 1500 TV
Lost Vermonters is offline   Reply With Quote
Old 04-16-2016, 07:48 AM   #2
ManlyMan's Avatar
If you open a couple of faucets in the RV it will release some of the pressure and the filter housing should loosen.
ManlyMan is offline   Reply With Quote
Old 04-16-2016, 07:54 AM   #3
Duh, of course it will and did. I love this place. Even helps me a stupid days.
Silverado 1500 TV
Old 04-16-2016, 08:02 AM   #4
ManlyMan's Avatar
One of the first mistakes I ever made with the filter housing was as I dumped out the anti-freeze the O-ring fell out of the top. When I reconnected, I had big time water leak. My wife mentioned that she had seen something fall out of the filter when I dumped it and sure enough we found the O-ring on the ground where I had emptied the housing. Thank goodness she had been watching me.
Old 04-16-2016, 08:12 AM   #5
I bought a "Back up Pac" of Of rings for the whole house filter that we use,I Didn't Notice that the O rings were for 2 different size filters,and picked the Wrong one thinking they were all the Same! I am glad our filter is on the Outside! Youroo!!
Old 04-16-2016, 09:13 AM   #6
Forester Fred's Avatar
Location: On the road between New Hampshire and Florida
Something else to be aware of, at least on mine..... if you take the water filter housing off while the hot water tank is full ALL that water in the hot water tank empties out through the top of the filter housing. Ask me how I know.......
Fortunately as I found this out the hard way, the cabinet where the filter housing is located is a rotomolded type with a drain plug in the bottom. It all drained through the drain plug and all is good now. But, in the future I will either drain the hot water heater first or flip the water heater bypass valves closed while I switch out the filter.
2015 Forester 2301 - Chevy
Skip & Deb - Bridgewater, NH & Delray Beach, FL
Forester Fred is offline   Reply With Quote
Old 04-16-2016, 09:19 AM   #7
WFD
These are all good reasons to yank that filter out of the trailer and by pass it, and install a filter on the outside of the trailer instead, right on the water source, then it can leak all it wants and no damage done.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 04-16-2016, 09:51 AM   #8
Yep, that is on the list this year. Especially the cost of these filters. I already have an outside filter ready to install.
Silverado 1500 TV
Old 04-16-2016, 09:53 AM   #9
SeaDog's Avatar
After I get back from next weeks trip I'm going to remove the main water filter and install a tee to a 2gal pressure tank. I have portable filters for the potable water hose.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 04-16-2016, 03:15 PM   #10
Sea Dog,install a Shutoff valve to your pressure tank so it can be isolated when Winterizing! You will like the tank addition! Youroo!!
