07-24-2018, 10:35 AM
Finally screwed up after 19 years of using flush king.
Just wondering what others know or think. I charged the flush king with BOTH the Rv valve AND the flush king valve closed and the dump station pressure was 60 or more psi. I saw Water coming out around the flush king outside of valve and hurried to turn off water and right then I heard a small (not loud) pop inside behind the dock station. On my unit the 1.5” pipe from grey also connects to the 4-5” main drain. I’m pretty sure the valve that took the hit was the grey due to its small size. Hope not a cracked pvc pipe[emoji849]. I’m going to remove underbelly and inspect all. It suppose to rain forever so i guess I’ll just get wet to help with my anxiety. I’ll fill both tanks and hope no leak with NO pressure. What you think? I wonder if 70 psi would crack a pipe? Thanks for any advise or info in advance.
07-24-2018, 11:23 AM
Waste piping, valves and fittings aren't pressure rated. They're only tested to about 10 ft WC which is about 5 psig.
I'd suspect the larger 3" waste valve failed before I'd suspect the smaller 1½" valve due to surface area. The blades are the same thickness so the 3" would have more surface area of the thin blade exposed to the high pressure without support than the smaller blade would.
Now, having said that, there's really no telling what 'popped' it could be anything from one of the valves, to a piece of piping, to one of the fittings, to just a joint that wasn't glued well.
Hopefully it'll be something easy to get to and to fix.
Gotta go campin!
07-24-2018, 12:54 PM
OP quote: "... I charged the flush king with BOTH the Rv valve AND the flush king valve closed"
This caught my eye. Are you saying the black tank dump valve and grey tank(s) dump valve was closed when water was turned on to the Flush King? Maybe I am misunderstanding.
Chris and Pat
2023 Ram 3500 Cummins Aisin Dually, Auto Flex Air Ride Rear Suspension, B&W RVK3600 hitch
2022 Grand Design Reflection 303RLS
2024 Winnebago Minnie 2327TB B&W Continuum Hitch
07-24-2018, 01:27 PM
The grey was shut also.
Just got done opening the underbelly around the connections I was very surprised to find the valve assemblies are right there that was pretty nice did not have to remove my whole underbelly to get to it I just made flaps to get in there. I filled both tanks and waited and inspected all around the valve flanges both grey and black and waiting for leaks and see absolutely nothing. Thank God. I wonder if it’s possible with enough pressure for the valve to just leak around the edges with the sudden pop like that and not ruin it because it still doesn’t seem to be leaking by when I close it either, I guess time will tell if I have a slow leak from one of the valve gaskets. Again I’m so happy i absolutely see no leaks anywhere or water anywhere in the underbelly. I also checked all pvc for leaks and none I can see. I did take down one side so I could look in there and I put my arm and hands inside and there’s no water. Thanks for helping. Any other thoughts.
07-24-2018, 01:51 PM
Retired Navy
Did the water pressure perhaps push the Flush King off one of the tits on your outlet pipe?
2012 Lexington C Class
Toad: 2009 Honda Fit
07-24-2018, 01:58 PM
I did this once. Water pouring out of the underbelly.
I did the same thing you did. Open the underbelly inspect, test the valves all ok. I had to replace the insulation under the black tank as it was soaked.
Never had any issues with leaks etc for the next 5 yrs
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
07-24-2018, 02:29 PM
Wow. So it’s prob possible the valve and or packing can leak buy under pressure and then be ok. I bet if we did again by accident it may be worse second time. I was able to get my hands and socket on the 4 fasteners holding both valves together and they DID take a few turns before they were German (good n tite). 😬. Also flush king took some tightening. Thanks for everyone’s advise.
07-24-2018, 02:30 PM
No the flush king was fine. Thanks.
07-24-2018, 03:06 PM
So I guess it’s really possible since I saw NO water anywhere and filled tanks and waited 3 hours and saw no leaks from Valves, tanks and pipes I may be ok. Did I miss inspecting anything? Thanks again for all the help.
07-24-2018, 03:47 PM
Glad it didn't break anything. The popping you heard could have been a seal relieving and when you took the pressure off it, it went back in place. At least that's what I choose to believe!
Gotta go campin!
07-25-2018, 01:15 PM
Could have been back flow device or tank expanding
GMC Denali 2500HD 4x4
Columbus 381 FLC 2016
Flagstaff Ultralite 29 RLSS
2013 35 nights, 2014 105 nights, 2015 123 nights, 2016 18 nights 🙁
07-25-2018, 01:37 PM
Recently new!
Just curious, would not any pressure generated be relieved via the tank vents? If overfilled, would the water come up the drains or out the top of the vent on the roof?
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
07-25-2018, 01:43 PM
What about your auto vent for the Grey Tank under your sinks? Maybe they popped.
B and B
07-25-2018, 02:38 PM
I always use a pressure regulator and I put my Y-valve after it, so it affects both city water hose as well as tank flush hose. Might take a little longer to flush your tanks with the Flush King that way, but hopefully helps to avoid problems...
2018 Grand Design Imagine 2600RB
2019 Chevy Silverado 2500HD 4x4 LT Crew Cab, Vortec 6L V8, 4.10 Rear Axle
Equal-i-zer 1,200/12,000# Hitch
07-25-2018, 03:45 PM
The pressure never got to the tanks or vents. It was trapped between the gray and black termination valves and the flush king termination valve since he had all of them closed. So it had to be something in that small section of plumbing that relieved.
Gotta go campin!
08-09-2018, 09:04 PM
Love that Flush King!
2020 Rockwood 2608BS Ultra-Lite
Eaz-Lift 48703 Trekker
2018 Dodge Ram 2500 Cummins Diesel
