Old 01-06-2019, 09:53 PM   #1
First time trying WH and not working
So our water heater is not working. We tried all the online and owners manual troubleshooting to no avail. Then noticed the main 15 amp fuse had actually blown. We replaced it, but still had no luck. There is no fault light, and no propane smell. All othe propane appliances work. Any ideas? Thank you for all responses.
TV - 2002 GMC Yukon XL 2500, 8.1 liter (496ci), 4L85e & positraction with 3.73 gears
TT - 2013 Dutchmen Aspen Trail 3130 QBS
Drinks of choice: woodford reserve, knob creek & any great bourbon-just about any of San Diegoís craft beer and Pabst Blue Ribbon
Beachbourbon is offline   Reply With Quote
Old 01-06-2019, 09:58 PM   #2
wmtire's Avatar
What brand/model water heater do you have? Is it the gas/electric type and does the electric work if so? Not familiar with Dutchmen RV's as per your sigline, but it's probably the same as used in FR RV's.
I moved your question to it's own thread so as to not hijack the one you originally posted in.
2011 Flagstaff 831 RLBSS
As I've told my kids a hundred zillion times, "Don't exaggerate."
Old 01-06-2019, 10:10 PM   #3
Sorry about that...Atwood water heater.
Old 01-07-2019, 04:15 AM   #4
wmtire's Avatar
Since you have a Dutchmen, you may be able to get better help from our Dutchmen sister site:
Dutchmen Owners
Old 01-07-2019, 09:27 AM   #5
If a fuse blew then you likely have a ground in the wiring somewhere. You can check the wiring leading into the WH. If you don't see something obvious I would take it to a professional. Replacing fuses that blow can lead to a fire if there is a ground. Hopefully you are still under a warranty.
2013 Salem 26 TBUD, Centerline WDH, Goodyear Endurance Tires, TST 507 TPMS, Winegard Pathway X2/ Dish TV, Dual Honda EU2000i Companion/EU2200i w/extended tank, 2016 Ford F-150 3.5 L Ecoboost
Mad_River is offline   Reply With Quote
Old 01-07-2019, 02:07 PM   #6
TimVWulp's Avatar
Is there water in the hot water heater???? If you lift up on the relief valve very slowly dose water come out? If not the water heater valves are still in winter bypass. If no water and electric is on to water heater the heating element is burned out and the high limit safetys may be triped to shut off the propane.
Hope this helps Tim
TimVWulp is online now   Reply With Quote
Old 01-07-2019, 09:23 PM   #7
onetonford's Avatar
Hope this helps Tim
X2
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 01-07-2019, 10:31 PM   #8
Update
This is an Atwood gas/electric WH. We followed all the directions, and double and triple checked. We read posts and watched YouTube videos for troubleshooting. The tank has water, it is not bypassed, water comes out of the pressure relief valve, the 2 amp fuse on the WH is good, the other connections look good. I didn’t notice the 15 amp fuse at first because the labeling was a bit off, so I checked another 15 amp instead. In fact the fuse that was blown was a 10 amp that replaced a 15 amp. I didn’t have a 15 at camp, so put in a 30 amp I had just to see if it would start up. Still dead. No propane smell either.
I’m asking for help here to see if I missed something before calling a service tech.
Thanks for all the replies
Old 01-07-2019, 10:54 PM   #9
pjones1969's Avatar
Look at #33 in the diagram on this page, it’s a thermal cut off, mine blew last week. Like you I tried everything until finding this, you can’t tell by looking at it so you can remove it and check continuity. They are cheaper on Amazon, I have 3 spares now. It will not allow the WH to run on either electric or propane.
Also, check your u-tube for blockage before firing it up or you’ll probably blow another one..... a quick $12 mistake
https://pantherrvproducts.com/water-...rts-breakdown/
2011 Puma Unleashed 27SBU - SOLD
2013 Sabre 32bhok-6 - SOLD
2012 Ford F250 6.2 - SOLD
2017 Heartland Cyclone 3800
2016 Ford F350 6.7 DRW
B&W Companion
pjones1969 is offline   Reply With Quote
Old 01-07-2019, 11:12 PM   #10
Thanks! I did look at this, but did not remove it because I thought it looked ok. I’ll remove it and check closely. How do I check the u-tube for blockages? And what is the best way to remove them?
