Old 06-20-2014, 07:57 AM   #1
hrlyguy2's Avatar
first time with fresh water fill up ????
Filling my tank. Seen there is a heater switch next to my pump switch.Should I use that or ignite the water heater ?
Should I leave it on gravity or city while driving
2007.5 Chevy 3500Ltz cc lb Duramax
2010 Sandpiper 345 RET (SOLD)
hrlyguy2 is offline   Reply With Quote
Old 06-20-2014, 08:35 AM   #2
I would turn the Water Pump Off as well as the water Heater while going down the road in a (Towed) vehicle! Youroo!!
Old 06-20-2014, 08:36 AM   #3
scayne62's Avatar
I would say it depends on how many amps you are connected to, the electric side of the water heater pulls 13 amps I believe. I would leave it on city while driving so the pump does not run. be sure the water heater is FULL before turning on the electric heating element, if you do not make sure it is full it will burn out the element in seconds.
scayne62
2020 Heartland Torque 371
2019 Silverado 3500HD DMAX
https://www.epgsoft.com/visited-stat...00&format=jpeg
scayne62 is offline   Reply With Quote
Old 06-20-2014, 08:40 AM   #4
mark0224's Avatar
Make sure and bleed lines so there is no air in hot water heater, that switch should be for lighting the gas. If it is a suburban water heater open the panel, on the outside of trailer, and down near the bottom left there will be an on of switch and that will be your electric hot water switch. Make sure to turn it off when camping is done or you could burn up element.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 06-20-2014, 08:54 AM   #5
Berkshire 390QS
NO3putt's Avatar
Electric water heater off when traveling and water pump on only when needed.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
Old 06-20-2014, 09:17 AM   #6
hrlyguy2's Avatar
I figure to leave everything off while driving.Will be hooked up to 30 amp no water at site.Filled the tank with the with the water heater valve open .waited for water to pour out shut pressure valve off.
Tank should be filled .right
Old 06-20-2014, 09:45 AM   #7
Make sure all (3) bypass valves are turned for proper hot water flow. Have your F/W pump (ON) while you are using Hot water. Make sure you turn (OFF the 110v elect.supply on the W/H) before you run out of F/W! Youroo!!
first time, fresh water, water
