Originally Posted by Bama Rambler
Did you reinstall the check part of the anti-siphon valve? If you didn't, does water leak out of it when the tank is full?
I only removed the spring & plastic check valve in red below.
The big gasket blocks the small holes from leaking water.
The Vacuum breaker is in the overflow line, at the top of the tank. It did not leak. I will be checking it again at the next FW fill.
