Old 03-18-2014, 12:29 PM   #1
Fixing a loose connection to black flush
Hey all, I have a 2013 8311, and it has a black tank flush out connection that I can hook up a hose to and it sprays the inside of the black tank. Last time I used it I found that water was leaking from the inside of the camper. When I looked from the inside to where the connections are I could see water spraying out like the connection was not tight. It looks like a pain to get all the way to the inside of the connection. I was wondering if anyone knew how to make this type of fix.
RSpicknall is offline   Reply With Quote
Old 03-25-2014, 05:10 PM   #2
I had the same exact problem. I took the connection off from the outside of the trailer, tightened everything up (they had only about one thread holding the hose to the connector) and buttoned it back up. I did have to recaulk the connection on the outside of the trailer. I just used some clear poly caulk that I had used for some repairs to the previous trailer.
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
Old 03-25-2014, 06:24 PM   #3
Thanks, I will give it a shot.
