Old 03-28-2016, 07:33 PM   #1
Flagstaff 2003
Water heater switch wiring
sr0520 is offline   Reply With Quote
Old 03-28-2016, 07:36 PM   #2
Does anyone have a 2003 flagstaff? I can't figure out how to put the water heater switch wiring back together.
Old 03-28-2016, 08:48 PM   #3
Which switch inside or outside?
Rich5117 is offline   Reply With Quote
Old 03-28-2016, 09:41 PM   #4
Inside. It says water heater.
Old 03-28-2016, 10:18 PM   #5
Flagstaff 2003
If it is just the wiring to the switch you can connect either wire to the back of the switch it is just a pass thru switch.
Old 03-28-2016, 10:24 PM   #6
Flagstaff 2003
If you have the switch and light to connect that is a little more complicated. Go to manuals.adventurerv.net/Suburban_Water_Heater_Service_Manual.pdf you can get the suburban service manual there.
Old 03-29-2016, 10:34 AM   #7
Yes, it's the switch with the light. I'll go to the pdf. Thank you so much. I'll let you know how it goes.
flagstaff
