Old 07-08-2012, 06:59 PM   #1
Flagstaff 831BHDS Outside Kitchen
I have discovered that the sink drain on my outside kitchen is draining into the blackwater tank. I know this because I had sewer backed up into the sink and you can also smell the odor of the blackwater. I have not spoke to the dealer about this yet. Has anyone else has this issue? Can anyone tell me if this is considered proper plumbing for the outside kitchen?
rkmiller is offline   Reply With Quote
Old 07-11-2012, 08:26 PM   #2
Rsgtivr6's Avatar
Due to the location of most outdoor kitchens. It would not be feasible to drain to the grey tank. The kitchens are often near or behind the bathroom and the black tank is located directly below the stool. You would need to put in a small holding tank with a pump to get up and over into the grey tank, so they just did the easy road and put the drain to the nearest waste holding tank. This is common practice it seems.
TV: '17 Ram 2500 Big Horn CCSB CTD 4x4
TT: '18 Wolf Pack Limited 325Pack13
Tow Acc: Andersen Ultimate Hitch 2 goose ball mount, AirLift 5000 bags and HD compressor system
Rsgtivr6 is offline   Reply With Quote
Old 07-11-2012, 08:36 PM   #3
Dave_Monica's Avatar
Looking at the floorplan, it appears that they must have piped it to the nearest tank, which is the black tank. The piping for the grey tank shared by the bathroom and kitchen is only a few feet further.
I'd be raising a stink (no pun intended) with Forest River...no way this is acceptable.
Dave
Old 07-11-2012, 08:42 PM   #4
Rsgtivr6's Avatar
Looking at the layout, the OK sink is on the far end of the trailer. You would have to go over the black tank to get to the grey. Water can't flow up or level even to get that distance to the grey, so you would need to pump it from another holding tank under the OK sink. There is too much extra money involved in that route, as well as an extra tank, for them to do that. I can concur, it SHOULD be done that way, but how many things do we notice SHOULD be done a certain way on our campers and is done on the cheap? If you wanted to do it right, you could mod it in the way I posted or do like some do and just pipe it to a bucket under the TT and dump when full.
Old 07-12-2012, 09:23 AM   #5
Thanks for your comments. I did speak to Forest River yesterday about the issue. They did confirm this is the correct plumbing per the building spec of this Flagstaff. However that doesn't make it correct for me. I can do nothing now because I own it and will have to deal with the issue. It troubles me to think we wash dishes and prepare food where black water could be present. Get this.....Forest Rivers comments were; we added two traps to that drain line so you show never get any odor. Still doesn't make it right for me. So, anyone thinking of purchasing a unit with outdoor kitchen should question your dealer about this problem.
Old 07-12-2012, 09:34 AM   #6
ironj's Avatar
Rvguy (prime time rep ) and i covered this at length recently....there is no cost effective nor ' easy ' solution. I know of no similar layout where it does not work that way. My trailer was delivered with a huge sticker in the sink saying it drains to black...
Another lacrosse owner did modify his to drain into an external bucket.....maybe thats an option for you?
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 07-12-2012, 10:12 AM   #7
Do you realize that your home drains are hooked the same way, especially if you have a septic tank. With 2 traps, if you keep water in them, there is no way for smell to come from the tank.
Old 07-12-2012, 10:36 AM   #8
You maybe correct about the septic tank backing up into the house and I think you are correct that the basic plumbing design is the same. However, if your septic tank at home backs up into your house then the water would flow out of the toilet before it ever gets the sink trap. The elevation of sinks alone would prevent overflow into the sink before the toilet overflows into the floor.
Old 07-12-2012, 10:39 AM   #9
TURBS's Avatar
Dunnnc is correct.
Your (grey) water at home goes to the same place as your (black) . Especially with a septic system.
Your bathroom sink in your home runs into the same pipe that your toilet does.
The only reason you had the (smell)
Is because you failed to monitor your waste water levels and they backed up into the sink. The only reason it didn't back up into toilet is because there's a shut off plate.
Old 07-12-2012, 10:40 AM   #10
Agree with you, but I was assuming (there's that word again) that the op was going to empty the tank occasionally and not wait til it backed up into the sink.
