Old 10-11-2011, 12:19 PM   #1
Question Flagstaff Micro Lite water pump location
Hello,
Would somebody tell me where the water pump is located in a Micro Lite 23FB? Is it located under the bathroom sink at the base of the water filter?
Thanks,
Randy
MrTLV is offline   Reply With Quote
Old 10-11-2011, 12:26 PM   #2
TURBS's Avatar
does it look like this ?
Google Images
If so than yes.
fill your fresh water tank a little bit and turn pump on .... trust me you will find it .
Old 10-11-2011, 12:32 PM   #3
No, therefore it must be in a different location. I tried just flipping the pump on but I did not hear it. Does it require water in the tank to operate?
Randy
Google Images
If so than yes.
Old 10-11-2011, 12:56 PM   #4
TURBS's Avatar
Yes. You must also turn a faucet on as well.
you should hear the pump running as they vibrate and are loud.
Old 10-11-2011, 01:03 PM   #5
Ok, Thanks for the info...
Randy
