Old 09-23-2013, 07:17 AM   #11
KyDan's Avatar
This is a photo of the outside workings of a gas/electric water heater.
Notice the square black rubber cover partially visible in the top center
of the photo?? It says push to reset in 2 places.
There are over heat thermostats behind there.
Push both firmly. If you have a tripped over heat t-stat it might reset
and start working.
If this fails it's definitely time for a meter and some deeper trouble shooting.
Let us know what you find and we'll try to talk you thru this.
Good luck- BE CAREFUL!!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 09-23-2013, 07:19 AM   #12
wmtire's Avatar
Originally Posted by pender98 View Post
I did have hot water on electric I ran it all out before switching to gas and the gas heated just fine so I cut that off ran all water out and switched by to electric and never got hot water again from electric side.
Just for clarity, when you stated you ran it on just electric first......did you happen to turn on the switch inside the camper?
I'm asking this because the inside switch controls the gas Direct Spark Ignitor only. If you have both the gas DSI and electric heating element on at the same time, either side only comes on according to it's separate thermostat calling for it to come on. They both can be used at the same time.
You water could have already have been heated by the gas, and then the thermostat shut it off cause the water was heated to it's temp. You may have thought the electric heating element was what heated it, but it didn't. (it could have been bad the whole time). When you turned off the heating element, you did see the gas operate as it should, but when you turned the gas off, the electric heating element didn't work (and may not have initially)
2011 Flagstaff 831 RLBSS
I’ve lost my scapegoat.
flagstaff, heater, water, water heater
