Old 01-10-2019, 01:07 PM   #1
Flexible tubing
Probably a really dumb question here, but what is the flexible tubing used in the water system called? Not the solid semi-rigid red and blue PEX. Iím talking about the opaque tubing with a red or blue line around it. It uses the same PEX crimp rings, so is it a different kind of PEX? 🤦🏼*♂️
btf66509 is offline   Reply With Quote
Old 01-10-2019, 03:24 PM   #2
Head Rambler
Its braid reinforced tubing. Most big box home improvement stores carry it.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 01-10-2019, 03:41 PM   #3
I figured it was something simple and common. Thanks Bama!
Old 01-10-2019, 03:52 PM   #4
inside and outside diameters are not standard. take a piece with you to avoid multiple trips to the store.
Kimber45 is online now   Reply With Quote
Old 01-10-2019, 04:22 PM   #5
They only use the PEX type pinch clamps on both types of tubing because that is what they use the most of.
Keeping two different styles of clamps and paying someone to carry a nut/screwdriver would make your rig cost like $1 more!
Days Camped: '16=46 '17=30 '18=51 '19=27
