Old 04-28-2014, 10:56 AM   #1
Flush system leak
Hello my name is Jack. I have a question about my black tank flush system. I have a 2011 blue ridge 3025rl (we absolutely love it)! I noticed that when I flushed the black system recently that I had a leak. I followed the line from the sewer control in the underbelly and the leak is coming down from where the flush line goes into the floor under the shower. How do I access this line to find the leak? Do I have to take the shower apart? I figure there might be an easier method to this repair. Any help would be appreciated. thanks
jbmorgan90 is offline   Reply With Quote
Old 04-28-2014, 11:11 AM   #2
If it is a Fac.install flush system you will have a Valve like this between the wall and where it goes thru the floor! I had to cut a wall to gain access to the (Secret) area! The Fac.said later that I should have taken the bottom of the closet out in the bathroom? I made a cover door instead,now I can remove door for other needs!Youroo!!
ID:	51133   Click image for larger version
ID:	51134   Click image for larger version
Old 04-28-2014, 11:18 AM   #3
Thanks Youroo! The only problem I have is that where it goes through floor would put it behind the shower wall. I cant believe they would put it there with no access besides taking the shower out. Seems like poor planning.
Old 04-28-2014, 11:28 AM   #4
I cant believe where they put lots of things! Do you have a enclosed underbelly? If not you could disconnect your hose at the blacktank nozzle and run a new hose to another location like the (Aftermarket sprayers)!Youroo!!
Old 04-28-2014, 11:35 AM   #5
yes its enclosed. I guess I will continue to research it before I tackle it. I don't want to take the shower out if there is no access behind/under there. A plumbing diagram would come in handy about now!
leak
