Old 07-28-2015, 05:03 PM   #11
Forester Fred's Avatar
Location: On the road between New Hampshire and Florida
Originally Posted by mabu_x View Post
Thanks, Sharon and Captain Jack!
I may not be phrasing my question right. As Lefty mentioned, in order to "fill" the fresh water tank, I have to hold the male garden hose end to the male fill hose end... and that just doesn't sound like a standard operating procedure to fill a fresh water tank. In fact, I am not convinced that this fill hose is a "gravity" type. Spilt water would travel down the fill hose and drop inside the compartment. I would suspect that the hose is made for a connection of some kind... but what kind?
Sharon, I've been looking at that fill adapter, but the tube on it is 5/8"... the fill hose on the 2501 is 5/8" at the most... so I don't think it will fit.
Captain Skip, Is your fill hose also terminated in a male threaded connector? how do you connect the fresh water source to your fill hose?
Thanks Again! Trip is in two days... so I need to start the sanitization process tonight.
Mine has male threads but they're much larger than the hose threads. There's a threaded cap that goes on them. The hose actually fits inside the water fill for an inch or so. To make life easier I bought one of the fill extensions to attach to the end of the garden hose.
2015 Forester 2301 - Chevy
Skip & Deb - Bridgewater, NH & Delray Beach, FL
Forester Fred is offline   Reply With Quote
Old 07-28-2015, 05:24 PM   #12
Aha... ok... I may have a different setup. On the 2501, the fill hose attached to the pump/filter housing is a smaller diameter than a garden hose
Thanks Captain!
mabu_x is offline   Reply With Quote
Old 07-28-2015, 07:15 PM   #13
Average Joe
MrJoe's Avatar
Thanks Captain!
Are you sure you are not trying to fill via the winterizing port? My fill is on the passenger side exterior. Black cap with a large enough opening to stick the hose in.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 07-28-2015, 09:49 PM   #14
MrJoe, apparently that was exactly what I was trying to do. So I found the problem and the problem is that I am an idiot.
All fixed.
Well... I'll probably continue to be an idiot, but at least I am now an idiot with a full tank of fresh water.
Old 08-04-2015, 08:16 PM   #15
I have a Coachman Concord which I purchased new in 2013 (I am a true novice). I was able to fill the potable water tank with no issues. This year I have had a problem When I connect to the potable water connection nothing is going into the tank at all the water runs for a while and then it just drains out under the chassis. It almost appears there is a valve not open somewhere. Any ideas?
RobertD is offline   Reply With Quote
fresh water, tank, water, water tank
