Old 10-05-2013, 09:27 PM   #1
Fresh Water
Hooked up as normal to fresh inlet-never had the fresh water tank above 5 to 6 gallons, now its full and over flowing and coming out the over flow. Don't get it???? Help!!! It won't stop over flowing!
Slugger is offline   Reply With Quote
Old 10-05-2013, 09:32 PM   #2
Ford Idaho's Avatar
Turn off the water faucet and then tell us about your TT!
Old 10-05-2013, 10:09 PM   #3
bikendan's Avatar
sounds like a stuck check valve
Equalizer WDH
Old 10-05-2013, 10:27 PM   #4
Dave_Monica's Avatar
As Dan has said, the fresh water is leaking past the check valve on the water pump intake filling the fresh water tank.
Dave
Old 10-06-2013, 08:03 AM   #5
Herk7769's Avatar
Remedy for stuck/broken check valve.
To deal with this quickly is a trip to the local home store to but a one way check valve 1/2 NPT female to 1/2 NPT male and stick it between the pump inlet screen and the fresh water pump.
Since the pump's check valve is internal to the pump, the pump head must be rebuilt, replaced, or a new pump bought.
Name:	Shurflo Pump IPB.jpg
ID:	40693   Click image for larger version
File Type: pdf Classic Pump - pds-2088-422-144_444_ (1).pdf (150.7 KB, 24 views)
HAM CALLSIGN - KC3FFW
Old 10-06-2013, 08:09 AM   #6
Turned of at faucet, turned on pump and let run a bit and it stopped leaking, so as it has been said, it would be the check valve. Any other suggestions or possibility? What would be the fix if its the check valve and where would it be located. Thanks for the reply
Old 10-06-2013, 08:16 AM   #7
Ford Idaho's Avatar
Did a hand valve get moved by mistake?
City/fresh water tank connection right?
Old 10-06-2013, 08:27 AM   #8
City/fresh water connection is right--don't know what is meant by hand valve--its a hose to city water and a hose to RV system.
Old 10-06-2013, 08:33 AM   #9
Ford Idaho's Avatar
Ah, on mine I hook the hose to one connection for city and fresh water tank usage I then turn a valve by hand to select which one I want to use.
Old 10-06-2013, 09:16 AM   #10
Thanks to all the replied...at least I now have direction to go, starting with the check valve.
fresh water, water
