Old 01-01-2013, 07:34 PM   #1
moondog2000's Avatar
Fresh water capacity
My Forest River X-Lite is advertised as having a capacity of 34 gal fresh so when we wen't to Quartzsite boondocking this week end I thought I would have ample water for at least 2 showers Saturday nite. After my shower The indicator said empty. I had to go scrounge 10 gal up and pump it in. Today I opened up my water tank area under the bed and the tank said 27 gal and below that tmp gal 22.5. Does anyone know what tmp stands for and shouldn't my tank be a 34 gal tank or are they including the hot water heater ? I guess I'll have to carry spare water, a pump and a battery. I wonder if its expensive to have a larger water tank installed. Thank You Mike
moondog2000 is offline   Reply With Quote
Old 01-01-2013, 07:57 PM   #2
Ham Radio since 1970
N9ID's Avatar
I am guessing that 'tmp gal 22.5' was really 'Imp gal 22.5' and the Imp stands for Imperial. Imperial gallons are slightly bigger than US gallons.
HTH,
Mike
Mike & Nena Strong
2013 Cedar Creek 36RE
2012 Chevy Silverado Crew Cab 3500HD Diesel 4WD
Nights camped '14: 51 '15: 134 '16: 149 '17: 171
N9ID is offline   Reply With Quote
Old 01-01-2013, 08:10 PM   #3
Now that I look at it the plastic mold did not fill the bottom of the I . I should have caught that. Thank you Mike
Old 01-01-2013, 08:11 PM   #4
Twisty's Avatar
The water heater capacity is often included.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 01-01-2013, 08:37 PM   #5
Dave_Monica's Avatar
The WH capacity is usually included in the advertised water capacity. If you look on the sticker for camper's GVWR and CCC, the weight of all water is calculated and subtracted to determine the CCC.
Also 27 USG is 22.5 imperial gallons (1.2 USG = 1 imp. gal).
On another note, you'll never be able to draw the full capacity from the FW tank as the supply for the pump is on the side of the tank. There's usually a sump and the FW tank drain is off of that. Some has switched the pump supply to the drain sump to be able to use the tank's full capacity.
Dave
Old 01-02-2013, 10:43 AM   #6
I filled the tank last nite and drained it into a 5 gal bucket to figure the amount I am getting.I know the overflow vent prevents a full tank and the pump does not pull from the bottom, the drain fitting is the same level as the pump fitting so no gain there. I have 22 gallons to use from the tank. I guess I carry water jugs and a 12v pump and a battery till the warranty expires and then look at a bigger tank If I can find one that will fit. Thanks for the replies. Mike
Old 01-02-2013, 11:20 AM   #7
Graduate Member
RoadTrip's Avatar
or take super short showers...
--2009 Sunseeker 2860DS (Class C)
- one Hotwife, and two boys under 2(with one on the way!)
2013 - 53 days
2012 - 26 days
RoadTrip is offline   Reply With Quote
Old 01-02-2013, 04:49 PM   #8
I did take a super short shower. I just looked at the tank and it looks 1.5" low because of the overflow. I going to the hardware for tubing and maybe put a loop in the hose above the tank and maybe I can fill the tank to the top and it won't siphion out.This might give me 2 more gallons.
Old 01-02-2013, 05:35 PM   #9
itch'n to road trip
campnqueen's Avatar
Send a message via AIM to campnqueen Send a message via MSN to campnqueen Send a message via Yahoo to campnqueen
Who needs a shower anyway...they are sooo over rated! :O
2012 Ford F-250 King Ranch Super Crew Cab 4x4 "Mae West"
2014 Work & Play 25ULA "Ula"
Paula Drake, Ken Cooksey, Sunny Delight & Valor
Jasper Ga.
campnqueen is offline   Reply With Quote
Old 01-02-2013, 07:35 PM   #10
Thats what I'm talking about,Maybe a little spit bath for the pits and good to go.
