Old 08-17-2016, 08:22 AM   #1
Fresh water drain
I have a 2007 Fr All American toy hauler. Where is the drain for the fresh water tank located?
It has 2 outlets on the side. I assume 1 is to fill and the other is the vent.
I have looked under the unit and not found the drain.
kholland is offline   Reply With Quote
Old 08-17-2016, 08:44 AM   #2
SeaDog's Avatar
This is only a guess but I would think the Outlets you are talking about are one to fill and the other for city water. the location of these does not mean the FW tank is located in that location. search the underside for the tank they usually have a small drain valve or cap located in the side of the tank. Wish I could tell you more let the forum know what you find so others can benefit from your experience.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 08-17-2016, 09:08 AM   #3
Thanks for the reply. The 2 outlets on the side are not for the city water connection. They are not threaded.
My unit is insulated and covered underneath so I have not seen the tank. Not sure how far from the fill neck it is located.
Old 08-17-2016, 12:13 PM   #4
bikendan's Avatar
Those are probably the low point drains.
Equalizer WDH
Old 08-17-2016, 01:08 PM   #5
I am asking about the drain for the tank. I understand the fill ports. Anybody know where the drain valve is for the fresh water tank?
Old 08-17-2016, 04:40 PM   #6
Thurman's Avatar
"khollan", as stated these fresh water tanks may not be, probably are not, located close to the fill port. On my TT the fresh water drain is a good fifteen feet away from the actual fill port. And no, my fill port is not threaded for a water hose either. Just remove the cap and there is a hole to stick the water hose into. Go to Forest River's website, find the "contact us" tab and send them an email message. They have never failed to respond to a question that I ask.
Thurman is offline   Reply With Quote
drain, fresh water, water
