Old 05-01-2012, 08:15 PM   #1
Fresh water drain
I'm not sure how the drain works. There is a piece at the end of the tube about an inch long, it has a hex at the top, threds down the outside, and a small o-ring at the bottom. Is there a cap that screws on to this? Is the drain open without this cap? Thanks to any ideas.
dino1602 is offline   Reply With Quote
Old 05-01-2012, 08:21 PM   #2
bob213's Avatar
Sounds like you are missing the cap. Should be the same type of cap as your low point drains. Put some water in the fresh water fill and see if it runs out. A 1/2" pvc cap will probably work.
bob213 is offline   Reply With Quote
Old 05-01-2012, 08:26 PM   #3
Or a 1/2" pvc shut off valve.
Old 05-01-2012, 10:02 PM   #4
bikendan's Avatar
dino, it's always helpful if you post year, make and model of RV you have, when asking for answers.
