As mentioned, you can replace that drain valve.
You can also remove the broken piece that turns by using pliers and being careful.
I've replaced just the barrel (with the handle) by pushing up on the bottom of the valve (where the water comes out) with one side of the pliers and gripping the lip (near where the handle was) with the other side of the pliers, pushing it up and out of the housing. It is just a slip fit in the housing.
You can remove the new one in the same manner and install it in the original housing if so desired. Only suggesting if you are somewhere without a drill to remove the rivets or lack the time to replace the entire valve.
