06-15-2015, 09:38 PM
Fresh water fill location
Where is the fresh water fill located in the cedar creek 38ck?
06-15-2015, 09:42 PM
Real close to the city water fill.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
06-15-2015, 09:45 PM
I see that the lever to switch between the city and water fill. I guess my question is how to treat to the system with the setup of that type of water fill.
06-15-2015, 10:06 PM
How do you mean "treat" the system?
TURBS
2011 32bhok Sabre
06-15-2015, 11:02 PM
If you mean sanitizing with bleach, add bleach to your fw house with a funnel and then push the bleach into the tank with water. I did it this way to sanitize my hoses.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
06-16-2015, 06:03 AM
Awesome thank you for the advice. I just didn't know how I would push the bleach solution into the system to de sanitize it. Thank you!
06-16-2015, 06:45 AM
Originally Posted by Lennyg
...the system to de sanitize it. Thank you!
Why would you want to "de-sanitize" it?
06-16-2015, 08:43 AM
I had read that you want to sanitize the fresh tank, first time you use it or if the trailer has been sitting unused for awhile. Is that not right? I guess I meant sanitize haha
06-16-2015, 08:47 AM
You are correct in wanting to sanitize it, was just ribbing you with your "de-sanitize" statement.
07-03-2015, 01:15 PM
I tried a different way to see if it works. First, I put the suction hose normally used to winterize the system I to a gallon jug of bleach. Then I turned valve on for the winterization configuration of pumping. I then turned on the pump. I connected the exterior shower discharge hose in that compartment to the tank fill making sure that the valve was in the gravity setting. I figured that the bleach would be pumped through the piping and discharged back into the fresh water holding tank. I then topped off the fresh water tank with the water supply from my house. I will let it sit for about 12 hours then drain it from the exterior shower hose into the black water tank rinse fitting. I will use this to rinse when I dump at Cabellas in a day or two. One question that I have however. Is there a back flow valve on the piping for the black water rinse out? My understanding is that the rinse out for the black tank is sort of like a sprinkler head in the tank.
07-06-2015, 09:27 AM
Just saying here ... in about any RV water tank I'm familiar with (60 gal) ... a single cup of clorox would be a plenty ... otherwise ... it'll take forever to get the taste of clorox out of the system.
07-07-2015, 07:53 AM
I think you are right about the quantity of bleach to use. I would have been better off to have used a small bottle of bleach rather than the gallon. Oh well. I guess I have a lot of flushing of the fresh water tank to do
